| rtalich |
Jun 16 2015, 10:55 AM
Member ![]() ![]() Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
For Sale: 1974 Porsche 914
Hate to do it, but I’ve decided to sell my car mainly due to lack of interest. I simply can’t dedicate the time, effort and (most important) money into this car/project anymore. I’d really like to keep it, drive it… but I have to draw the line at some point and we just have too many other commitments. A bit of History: I’ve owned this car for about ten years and it has always been garaged. FWIW, I have previous owner records to prove this car was originally from Arizona so it has VERY little rust. Here’s a list of items I’ve done during the time I’ve owned the car: No particular order: • Rebuilt the 2.0 liter stock motor to a 2270 with a Raby kit. Jenvey TB’s and SDS EFI. With Tangerine Racing Exhaust. • While motor was out, I had both trunks and engine bay Rhino lined. • Replaced all four brake rotors, calipers, pads with PMB Performance parts and ATE Superblue Brake Fluid. • 5 Lug upgrade and 16” Phone Dial wheels. • Stripped interior and lined with Por-15 • Cleaned and reconditioned the fuel tank with Por-15 • Updated fuse panel • Aluminum pedal board • Swepco 201 gear lube Current State of Car: After I built the 2270 kit I started collecting parts to build a big turbo motor, 2576 to be exact. After about 3-4 years I had all the parts acquired but did not have the time to assemble so I solicited the expertise of Mark of Original Customs to build the beast. Here is a list of components that make up the build: • Custom machined/clearance GA case. Clearance work done by Jake at Aircooled Technology. • TDC (Thermal Displacement Coating) Engine case. • Rotating assembly balanced by Jake at Aircooled Technology • DPR 82mm Crank • 9540 Cam • Revmaster 38mm oil pump, full flow • 100mm Turbo Nickies • JE 100mm Piston, dished and coated • 5.5” Type 1 H-Beam Rods • Pauter Roller Rockers • ChroMoly Pushrods • Custom Billet Taco Plate • DTM • Garrett T3/T4 Ball-Bearing Turbo, TDC coated • TurboSmart BOV • TurboSmart Boost Tee • Tial Wastegate • Turbo prep’d LE 200 Heads • Custom Exhaust, Tangerine Racing • Custom intake plenums, M-Spec Racing • Custom Fuel Rails, Extrudabody • SDS EFI • 70mm Ford Throttle body • Kennedy Stage II clutch with six puck pressure plate • Custom surround tin, Original Customs • Setrab oil cooler with fan • Motor build complete in July of 2012 • Install complete in August of 2013 The car is an absolute blast to drive! What’s left to do: While I had no plans of racing the car, it was destined to be my daily driver. So I had plans of installing a water/meth intake injection system to keep the intake temps in check. The car is drivable without this system in place due to the cooler weather we have around here but I wouldn’t push it until some sort of intake cooling system is in place. Like I said… daily driver. I know that I will never get the amount I put into this car but we all know we are not in the hobby to make money, right. Just the turbo motor alone, in parts, I’ve spent at least $15,000. So, I’d like to sell the whole package for Thanks for looking. Pictures of the motor build can be found here, http://www.originalcustoms.com/invoice/images.php?p=143. EDIT: Mark @ Original Customs has offered a discount to the buyer. See his post here. -Rob Attached image(s)
| rtalich |
Aug 4 2015, 11:58 AM
Honestly... what is 'scaring' people away from even making offers on my car? I don't get it. Compared to some of these other cars that are posted... I know $15k might be too much for some people, but look at what you'd be getting. Offers? No jokers please. You can't even buy the motor alone for this price!! Thanks for looking. I think people are scared off by the complexity and the fact that it is a great build which is perhaps 85% finished...and with a car like this, the last 15% is the hardest. The concept is killer, but can it actually be made to be a "DD" with this big four AND a turbo? I have turbo experience (Miata's) and in a Miata, you can turbo under 6psi without an intercooler...but no one would ever recommend it or say it is the right way to go. You need the intercooler to lower the intake charge to prevent detonation and melting your pistons. The killer in a turbo engine is excess heat and a poor tune...too lean and you are bending rods. It appears that these are two problems that have not been figured out here (no intercooler and no real dyno time) and they are big question marks, and since you asked, this is what is scaring people off. I myself think there is room for an intercooler somewhere, and might suggest a water to air intercooler, maybe mounting the heat exchanger in the front trunk and intercooler in the engine bay. Is the intake charge really the issue? Or does the whole engine get too hot? These are probably the questions on other people's minds, I am trying to help by voicing them...so you can get your very very very cool car sold. Agree with the above posts. 15k is a great price, but I think people(myself included) are worried that engine needs careful tuning and meth injection to make it safe. If you mess it up there are costly consequences. It's simply the fear of the unknown, as that engine and trunk have lots of hoses and wires to learn and sort out. Spend another 2k on it to get cooling and a tune...you can sell for full asking price. Especially on eBay. Might help to offer the buyer some assistance on sorting the last needed details out. I totally get where you are coming from and anyone with turbo experience (or mechanically inclined for that matter) should not be scared off by the ‘complexity’ of a turbo motor. There really isn’t anything complex about it. It’s simply just an induction system. Honestly, I think carbs are way more complex, but that’s just me because I’ve never messed around with them. But if I were to do my research and dive into them, I’m pretty sure I can figure it out. Same goes for this motor. As far as being 85% complete… IMHO, that’s just a matter of opinion I guess at best. When I can, I’ve driven this car to work and it’s a blast!! It’s about 40 miles round trip, so it is drivable as it is. I guess the most important thing that people need to understand is that this motor (and I can’t say it’s true for all turbo’d engines) is not on boost all the time and so therefore does not generate the heat they are stereotyped for. The only time you see any boost is when you are moderately to aggressively accelerating from a stop and/or passing someone on the freeway. In any other circumstance it behaves and drives like any NA motor. As far as maximum boost… you said it yourself and I’ve read/researched mainly air-cooled motors, a lot of useful information on shoptalkforums, if you keep the boost low (below 10 as a rule of thumb) you really don’t need any sort of intercooling or meth setup. If you want to see the full potential of this motor and most likely shorten its life span then go ahead and turn up the boost to whatever you like, but only then will you need to add intercooling and/or meth. But that was not my intention for this motor. It is completely drivable as it is and should live a long happy life! It’s probably similar to driving a car with nitrous (I never have but it’s what I imagine it to be like)… it drives and behaves like a NA 2.6 liter motor until you press on the go pedal, build up some boost, and it goes!! The go pedal is like the nitrous button and 8 or 9 psi is enough for me. Tuning this motor is no different than tuning any other air-cooled motor. You must have an AFR meter/gauge, which I do. I did have it on a dyno and professionally tuned but my dyno time and results were cut short and inconclusive because the clutch I had in there kept slipping when I built up any boost. I since put in a stage II clutch with a more aggressive PP and got rid of the slippage. But since my only goal for the dyno was to get a decent tune I never went back to see what my actual HP numbers were. Great discussion so far… keep the comments/questions coming. Something to also keep in mind and may be helpful/useful information to some. I had nothing to do with architecting this motor combination. I completely left that all up to Jake. From the turbo prep’d LE200 heads to the 100mm turbo V2 nickies. The only thing I told him was that I had a set of Pauter ratio roller rockers and a T3/T4 Garrett ball bearing turbo. And he put together a killer combo like he always does!! And then I had it built by another reputable person, Mark from Original Customs. Hope this helps ease the minds... |
rtalich FS: '74 914 Washington State Jun 16 2015, 10:55 AM
rtalich :bump:
Over 200 views and no interest? Any ques... Jun 19 2015, 11:14 AM
Zimms
:bump:
Over 200 views and no interest? Any que... Jun 19 2015, 06:46 PM
2mAn
:bump:
Over 200 views and no interest? Any que... Jun 20 2015, 12:52 AM
matthepcat Sweet car. What kind of power do you think it is p... Jun 19 2015, 11:26 AM
rtalich
Sweet car. What kind of power do you think it is ... Jun 19 2015, 03:37 PM
rhodyguy Look at it this way folks. You would be buying a d... Jun 20 2015, 10:38 AM
rtalich
Hey Rob,
do you know what the compression ratio... Jun 22 2015, 09:07 AM
rhodyguy Or buy the car, go to a less performance engine, S... Jun 22 2015, 09:45 AM
2mAn this really is a great looking car and I would be ... Jun 22 2015, 07:36 PM
rtalich
this really is a great looking car and I would be... Jun 23 2015, 08:01 AM
Mike Bellis Buy it Simon! Jun 22 2015, 08:58 PM
Evil914 Me LIKE. A LOT! :woohoo: Jul 21 2015, 07:47 PM
rtalich Bump and here are some more pics... Jul 24 2015, 12:14 PM
rtalich a few more pics... Jul 24 2015, 12:17 PM
matthepcat Such a sweet engine.
Would love to see some recen... Jul 24 2015, 03:23 PM
rtalich Hahaha... kind of hard to hold the phone (video de... Jul 24 2015, 04:23 PM
cconcepcion I don't see an asking price..... Jul 25 2015, 12:15 PM
cconcepcion Nevermind...found it. Jul 25 2015, 12:17 PM
rtalich Bump and price reduction... $15k Aug 2 2015, 08:53 PM
rtalich Honestly... what is 'scaring' people away ... Aug 3 2015, 01:46 PM
achman_73_2.0
Honestly... what is 'scaring' people away... Aug 3 2015, 02:42 PM
rhodyguy What would a Miata owner, that didn't break th... Aug 3 2015, 04:22 PM
matthepcat Agree with the above posts. 15k is a great price, ... Aug 3 2015, 10:34 PM
achman_73_2.0 "There really isn’t anything complex about... Aug 7 2015, 09:51 AM
mepstein Great explanation. Seems like a type 4 that has th... Aug 4 2015, 12:17 PM
rhodyguy We have a pt cruiser turbo gt ho. In the world of ... Aug 4 2015, 02:51 PM
rtalich
We have a pt cruiser turbo gt ho. In the world of... Aug 5 2015, 10:49 AM
rhodyguy if you're going to busy i can show it for you.... Aug 5 2015, 11:02 AM
Chris914n6 Intercoolers are dime a dozen on Ebay, expect to p... Aug 7 2015, 06:16 PM
achman_73_2.0 Smaller and easier choice might be a good water to... Aug 9 2015, 09:01 PM
rtalich
My opinion is not that $15k is too high for ... Aug 10 2015, 10:30 AM
rtalich Here is a quick video I just took. Sorry for the p... Aug 10 2015, 03:36 PM
achman_73_2.0 I'll be completely honest, it seems to run pre... Aug 10 2015, 06:25 PM
rhodyguy no snapping no popping no nothing. as noted nice i... Aug 10 2015, 07:09 PM
rtalich
oh…wipe the dust off the dash. <_< :sto... Aug 11 2015, 08:33 AM
rtalich :bump:
Thought I'd try this again. Slight u... Jan 3 2017, 10:36 AM
matthepcat I really like this car. Did you end up installing ... Jan 3 2017, 01:49 PM
rtalich
I really like this car. Did you end up installing... Jan 3 2017, 02:48 PM
rhodyguy What about the dust? <_< remember? :D Jan 3 2017, 03:01 PM
McMark I'm willing to offer 10% off my normal labor r... Jan 9 2017, 12:21 PM
keske968 I would jump at it if I had the cash on hand. Jan 10 2017, 06:50 PM
Mike1981 Hello
I have been trying to follow this thread
I... Jan 15 2017, 01:43 PM
rtalich SOLD!! Jan 18 2017, 03:05 PM
rhodyguy :cheer: :first: :trophy: Jan 18 2017, 03:23 PM
matthepcat I was wondering if the shop talk forums guy was go... Jan 18 2017, 04:16 PM
turbonet What a steal!!! I would have bought th... Jan 22 2017, 09:32 PM
rtalich Yes, it was a steal!! However, here is th... Jan 25 2017, 04:17 PM
lostreasure is this car still available Jan 29 2017, 06:37 AM
rhodyguy Nope. Too late. post #45. Jan 29 2017, 11:25 AM
BBergen I wish. I wish. So Close.
I am the guy from the ... Mar 11 2017, 10:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 07:40 PM |
