1911 L-jet. How to get a good Idle., What to do get a 900 to 1000 rpm idle? |
tach |
Aug 6 2015, 05:37 PM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
I can not seem to get the idle where it should be. Its idle is either to high 1350 rpm or to low, as to where it will eventually quit running. The engine runs great with plenty of steady power thru out the power band.
What to do get a 850 to 1000 rpm idle? 1974 1.8 with these modifications. 1974 1.8 with larger pistons Keith Black pistons 1911 Stock L-jet. 8.2:1 CR. Stock Bosch injectors. Raby 9590 cam kit. 96mm Keith Black flat top pistons. Stock distributor-Pertronix. Stock heads, valves and valve diameters. 1.8 SS heat exchangers. Triad Exhaust. Newly rebuild engine. |
Valy |
Aug 7 2015, 01:00 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I don't agree the distributor is the problem as the timing is set at idle on LJet.
Here is what you need to do, in this sequence. 1. Do valve adjustment. 2. Make sure there are absolutely no vacuum leaks. 3. Adjust timing at idle, all distributor vacuum lines disconnected and plugged. 4. Adjust idle screw at AFM 5. Check 3 and 4 again if necessary. Keep in mind that the cam you have doesn't like low iddle so you will probably need to compromise for a slightly higher idle. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:21 AM |
