Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
Dave_Darling |
Aug 8 2015, 05:54 PM
Pull the pads out and see if the noise continues. If so, inspect where the rotor goes through the caliper. Might be the edge of the rotor rubbing on the bridge of the caliper; this happens when you use Six rotors (solid) with -4 calipers. Might also be happening with your mix of parts.
--DD |
Krieger |
Aug 9 2015, 08:19 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Pull the pads out and see if the noise continues. If so, inspect where the rotor goes through the caliper. Might be the edge of the rotor rubbing on the bridge of the caliper; this happens when you use Six rotors (solid) with -4 calipers. Might also be happening with your mix of parts. --DD (IMG:style_emoticons/default/agree.gif) I had this problem on one side, but not the other. Just loosed rotor and move a little. Check both top and bottom of rotor for clearance. I think I have about 3mm on each side. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:57 PM |
