| Chris914n6 |
Jul 23 2014, 08:24 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Dusted off another one of my projects from when I first built my waterpumper. Heater and A/C replacing the factory fresh air blower unit.
History. I built the unit using a tube/fin core from my Uncle's buddy Dave @ Hotrod Air. HRA went under in the recession and so did the company that actually made the cores. Oddly enough this is a benefit despite having made some really nice wood vacuum forming bucks. The good news. For version 2 I went with separate heater and evap cores. The heater is off the shelf, I just need to trim the tubes. The evap I'm having made by a company I met at the 2013 SEMA show and is modern plate type. Blower is a 3 speed. The nitty gritty. Uses stock controls and stock air deflector boxes. Hoses run Pass side like DPD/VPC. I did design a setup for modern controls and deflector boxes with a separate side vent path, but it's a bit complicated to make. I have plans to offer 3 versions. Model B - A/C and heat for us waterpumpers. Runs recirc through the heater tube holes so no cutting. Unit is too tight of a fit for fresh air. I'll have an optional drainage piece for those that don't seal the grill. Model A - A/C only for aircooled cars. Because the heater tube holes are being used for heat, air intake will be from the grill opening. You could cut a 2.5" hole in the cowl for recirc instead if you wanted or use just one heat exchanger. Model H - Heater only for waterpumpers. Same unit as the A/C only except that recirc is possible through the heater hose holes OR model B with no evap, haven't decided yet. In the kit - Main unit, mounting brackets, air hoses & clamps, blower wiring, expansion valve, instructions. Options - Cabin filter. Grill water drain. The other pieces... Condensers- it depends on the radiator you using and what you can make fit, no point in me trying to keep an inventory. The exception could be a replacement to the DPD/VPC Condenser unit for air-cooled cars, I haven't gotten past doodles yet. Receiver-driers of the universal type can be had on Ebay for under $15 shipped, I'll pick one out for you, same with the pressure switch. Hoses, too many variations and too much overhead for me, but Vegas has 3 places that will build them on your car so I assume that's practically everywhere. Prices trend $100-$150. Hard lines- Research has spec'd it as 6063 aluminum. DPD/VPC used hard lines along the rocker and up the wheel wells. Heater hose- nothing special about it but it's long and 5/8"ID. Prices... about the same as the Hotrod kits. Manufacturing time is unknown and the biggest factor of course. I will have to buy 50+ evap cores to make this happen, so even if you are a year or more away from buying one speak up. Any feedback and who wants one? |
| Chris914n6 |
Aug 9 2015, 11:37 PM
Stalled yes, but not out.
Been a series of unfortunate events. Electrical went to gremlin paradise during the time the car's been stored, missed my WCC deadline and my window. Then June was hot as hell and I couldn't stay outside for any significant time. My WD Black HDD has failed twice since May, lost the design files and the suppliers list. Luckily I still sketch/draft some things on paper but it's been like starting from scratch. Add to it I'm a pretty busy fellow without "challenges". |
Chris914n6 Under cowl A/C unit design input thread and gauging interest Jul 23 2014, 08:24 PM
rnellums In for H Jul 23 2014, 10:24 PM
Chris914n6 I promised a pic in another thread. Problem is I c... Jul 23 2014, 11:03 PM
914dave I'd be interested in an AC only unit for my si... Jul 24 2014, 04:38 AM
Chris914n6
I'd be interested in an AC only unit for my s... Jul 24 2014, 01:43 PM
andys
The smallest aftermarket parallel flow condenser... Jul 24 2014, 02:49 PM
DBCooper Model B for me. I'm so happy you're taki... Jul 24 2014, 06:58 AM
Philip W. Model A --
so do i understand correctly that thi... Jul 24 2014, 07:27 AM
pdlightning
Model A --
so do i understand correctly that th... Jul 24 2014, 12:33 PM
Chris914n6
Model A --
so do i understand correctly that th... Jul 24 2014, 02:14 PM
76-914 +1 on a B, here. Jul 24 2014, 01:32 PM
Chris914n6 Ok, a teaser pic...
http://www.914world.com/bbs2/... Jul 25 2014, 01:52 PM
Chris H. Model B for me. Jul 25 2014, 02:04 PM
timothy_nd28 Thanks for taking on this project. :beer2: I ha... Jul 25 2014, 02:52 PM
Chris914n6 Thanks for the Thanks. I live in Vegas, it was kin... Jul 25 2014, 07:11 PM
racerx9146 As for me, been thinking of this for some time. As... Jul 25 2014, 07:35 PM
dadaDaveed Ooh, Model B for me! Texas only has two seaso... Jul 25 2014, 09:39 PM
7TPorsh Ya, type B....SoCal like Texas.... :D Jul 25 2014, 10:05 PM
Chris914n6 :smash: :smash: :smash: :smash: :smash: :smas... Aug 8 2014, 06:51 PM
JmuRiz A would be great, if only I could find some good h... Aug 8 2014, 08:30 PM
dadaDaveed How's it coming along? Oct 6 2014, 09:35 PM
Cairo94507 Wow AC in a Six would be perfect if it can be done... Oct 7 2014, 06:44 AM
timothy_nd28 I'm in model B Oct 7 2014, 08:27 AM
Philip W. if this is happening for sure(it will be my winter... Oct 7 2014, 08:51 AM
dlee6204
if this is happening for sure(it will be my winte... Oct 7 2014, 10:15 AM
Philip W.
if this is happening for sure(it will be my wint... Oct 7 2014, 01:17 PM
Chris914n6 It's moving at the speed of life....
I should... Oct 9 2014, 02:31 PM
aircooledboy I'm in for a Model B.
I've spent a lot o... Nov 10 2014, 09:12 AM
914forme Updates? Unit B for me please! :beer1: Jan 16 2015, 02:23 PM
Chris914n6 Almost done building my vacuum forming machine :... Mar 29 2015, 03:05 PM
Philip W. :cheer: :beer2: Mar 29 2015, 03:16 PM
wes :Qarl: Mar 29 2015, 04:56 PM
Chris914n6 Damn. Got a couple quotes to have the a/c hoses ma... Mar 31 2015, 06:44 PM
quadracerx Ill be in... Once you have inventory and are able ... Mar 31 2015, 08:13 PM
76-914 :popcorn: Mar 31 2015, 08:21 PM
Chris914n6 Hella fog light switch question. Are the new ... Apr 4 2015, 08:34 PM
Mike Bellis Hurry up!
I want to place my order. :D Apr 4 2015, 08:48 PM
db9146 I'm in for an "A" for an air cooled ... Apr 4 2015, 08:54 PM
jim_hoyland :) nice work :) Are you going to show us the pr... Apr 4 2015, 09:01 PM
kid914 interested in # 2 ( air cooled) :beer2: Apr 4 2015, 09:10 PM
Gary How's it going? I'm interested in a model ... Jun 25 2015, 05:02 AM
timothy_nd28 Did this project stall out :confused: Aug 9 2015, 12:06 AM
euro911 I'm interested in Model A, Chris.
WD HDDs sho... Aug 10 2015, 04:39 AM
boxsterfan Would love to learn more about what you are doing?... Aug 10 2015, 09:12 PM
Chris914n6 boxsterfan- I'm actually making a box that fit... Aug 11 2015, 01:10 AM
timothy_nd28 Happy to hear that you haven't waived the litt... Aug 11 2015, 10:57 AM
euro911 Should I keep my old condenser handy? ('70... Aug 11 2015, 06:27 PM
Chris914n6 timothy_nd28- I'm only selling the unit and th... Aug 11 2015, 09:03 PM
timothy_nd28 I totally agree with you. Back to my original que... Aug 11 2015, 09:23 PM
timothy_nd28 Any progress with the under cowl box? :popcorn: May 8 2016, 07:26 PM
Chris914n6 Essentially stalled pending a car that wants to be... May 9 2016, 11:00 AM
timothy_nd28 Do you happen to have any prototype boxes that you... May 9 2016, 12:11 PM
Chris914n6 Only have one working unit. The rest are cardboard... May 9 2016, 02:50 PM
Gary I'd be all over one for A/C today if available... May 12 2016, 04:34 AM
Mowog4 Has anyone come up with a solution yet? I am looki... Jun 5 2016, 06:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:23 PM |
