1.7l starting issues, motor starts if I disconnect cyl 4 injector cable |
b.stirbu |
Aug 9 2015, 04:14 PM
1974 daily driver Group: Members Posts: 27 Joined: 14-June 15 From: Netherlands Member No.: 18,848 Region Association: Europe |
Dear 914ers,
I'm quite in a pickle with my 914 1.7. The engine sometimes starts sometimes not (usually after it started, ran 5-10 seconds and then stopped and I couldn't manage to start it again). Messing arround in the engine compartment I accidentally unplugged the cyl 4 fuel injector and surprise the engine started and idled low. Tried again one, two, three times and he started succesfully, but as soon as I plug back the cyl 4 injector cable does not want to start again... What's wrong here? (the injector not, because I've swapped 3 with 4 and I still had the same problem). According to the attached current flow cyl 4 injector is in series with the cold start valve and the thermoswitch for the cold start valve.. Am I looking at the right diagram? I also don't know where current track 102 comes from. Also very interesting is that I removed the injectors 3 and 4 and placed them in two cups to see if they work, and I could start the engine in two cylinders (although the cyl 4 injector plug was connected) Cheers, Bogdan Attached thumbnail(s) |
b.stirbu |
Aug 16 2015, 01:22 AM
Ok, the fuel pressure regulator is stuck closed...I've pressurized the fuel line, started the engine and the pulsed (from another battery) from time to time the fuel pump to keep the engine running...it seems to be ok, I think I just need to tune the ignition timing..
During initial troubleshooting I did not consider at all the fuel pressure regulator as being faulty. Everywhere I read, everybody says that is a very reliable..I guess after 20 years of being unused he also cosidered retiring.. I've noticed something rather intersting for me.. if I pulse too long the fuel pump the engine starts to run around 3000 for 10-15 seconds like it was creating a vacuum on the fuel line and also engaging the fuel pump... |
Lo-Fi Version | Time is now: 9th June 2024 - 03:33 AM |
