Tranny in neutral despite shifter, Car currently broke down on road |
86motoman |
Sep 15 2004, 09:37 AM
Member Group: Members Posts: 200 Joined: 13-May 04 From: Walla Walla, WA Member No.: 2,064 |
Taking the 914 out for the first time to town. About 2 miles from my house and go for fourth. It's not thier...I wiggle a little more...still not there. I go back to third...nothing...second...first....stopped. I tried reverse, got it. Backed up to a wide place on the road and tried for first again...nothing...went back to reverse...nothing. Car is currently still sitting on the road. I tried to manually go back and turn the tranny shifter piece. It looked to me like it was moving around and the shifter (bushings etc.) is still operating.
'72 Tail shifter 1.7 Is there anyway I can fix it on the road? |
rhodyguy |
Sep 15 2004, 10:21 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
roll pin up inside the inspection plate at the rear of the trans. haynes, p.86, fig 5.21, part #11. when it starts failing it can bend in a manner that allows you to engage reverse but no forward gears(btdt). it is a 5x24double rolled pin. or the connection point in the tunnel has come loose. when you pull the plate, a bunch of gear lube will pour out. be prepared. you will need a new gasket too.
kevin |
Lo-Fi Version | Time is now: 5th June 2024 - 06:42 AM |
