Considering coilovers, Let me know your set-ups |
john77 |
Aug 12 2015, 03:07 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
The suspension on my car is tired, so I'm considering a complete overhaul. It's an AX street car, so I've started looking at switching to coilovers all-round.
I'd like to hear from anyone who has them about your set-ups/experiences: What springs you're running, what shocks you're running, did you have to reinforce your shock towers, are you running just springs up front or a spring/torsion bar mix, do you have raised spindles, and anything else you think might be useful. I've been looking at the elephant racing site, they have great stuff and there's obviously a lot of R&D behind their packages, but I'm wondering if I can put something together myself for less $$$$. Thanks John |
Mblizzard |
Aug 18 2015, 05:01 PM
Ok so was adjusting the rear ride height a bit and had a bit of an interesting failure.
First I have this insert with a clip to set part of the height. It looks like the entire weight of the shock rides on this clip. Is that correct? I had it put together like this and thought it was correct. But some how the brown threaded sleeve push the clip off and slide down the shock. Maybe I did not have it on all the way but I would find that heard to believe. Seems like a huge load for that small clip. Am I ding this right! |
john77 |
Aug 18 2015, 05:34 PM
Ok so was adjusting the rear ride height a bit and had a bit of an interesting failure. First I have this insert with a clip to set part of the height. It looks like the entire weight of the shock rides on this clip. Is that correct? I had it put together like this and thought it was correct. But some how the brown threaded sleeve push the clip off and slide down the shock. Maybe I did not have it on all the way but I would find that heard to believe. Seems like a huge load for that small clip. Am I ding this right! The Bilstein spring perch on my rear shocks sits on a similar style clip, and then the spring sits on the perch. I remember looking at it and thinking the same thing. Maybe someone that actually knows can chime in. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:49 AM |
