Garage Do's, what I did for mine |
76-914 |
Aug 18 2015, 08:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
With record breaking temps moving in this weekend I decided to insulate my garage door. It is westward facing and gets hot as Hell in the PM when the sun hits it. I used some 1" Styrofoam board. By 1:30 the garage door panel outside temp was 137 and the inside temp was 82. I showed my wife 15 mins later but the inside temp was now reading 100F. (IMG:style_emoticons/default/WTF.gif) So I measured the outside temp again and it was now at 157F. Looks like I realized appx 50F drop. I may add another 1" later on. Once the radiant heat was reduced at the panels I could feel the small exposed area of our roof radiating heat so I installed some radiant barrier material on the inside of the roof. Now I can work in the garage with a bit more comfort.
What have you done for your garage lately? |
rick 918-S |
Aug 18 2015, 08:08 PM
Hey nice rack! -Celette Group: Members Posts: 20,481 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
6" walls packed with insulation, vapor barrier and drywall. Insulated door, 8" in the ceiling and it's still not enough in the winter. Summer, it stays 65 when it's 90 outside.
somd914 |
Aug 18 2015, 08:28 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
6" walls packed with insulation, vapor barrier and drywall. Insulated door, 8" in the ceiling and it's still not enough in the winter. Summer, it stays 65 when it's 90 outside. Similar, 6" also with R-19 but did 7/16" OSB instead of drywall. Though drywall looks better, I prefer the durability of OSB; walls and ceiling are painted white for light reflection. Garage doors are insulated, 11.5 ft ceiling with R-30 above it. Also run a dehumidifier in the summer. With a fan running it is comfortable working in the summer. |
Lo-Fi Version | Time is now: 6th June 2024 - 03:55 AM |
