Garage Do's, what I did for mine |
76-914 |
Aug 18 2015, 08:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
With record breaking temps moving in this weekend I decided to insulate my garage door. It is westward facing and gets hot as Hell in the PM when the sun hits it. I used some 1" Styrofoam board. By 1:30 the garage door panel outside temp was 137 and the inside temp was 82. I showed my wife 15 mins later but the inside temp was now reading 100F. (IMG:style_emoticons/default/WTF.gif) So I measured the outside temp again and it was now at 157F. Looks like I realized appx 50F drop. I may add another 1" later on. Once the radiant heat was reduced at the panels I could feel the small exposed area of our roof radiating heat so I installed some radiant barrier material on the inside of the roof. Now I can work in the garage with a bit more comfort.
What have you done for your garage lately? |
JmuRiz |
Aug 19 2015, 08:46 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Smart move, I made sure to buy an insulated door when I built my garage. That and the insulated walls/ceiling help a lot.
...I also have a mini-split heat-pump in there too. With the insulation I just run the unit's dehumidifier setting and don't need to run the AC (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 08:56 AM |
