throttle return springs for IDF's, what works? |
machina |
Sep 15 2004, 03:22 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
I tried this dual coaxial compression spring setup but it feels like crap and is really hard to push. The carroll smith books like a compression spring because if it breaks, you still have some spring action.
How do you guys rig your throttle return springs on IDF's? Also, does it help to lube the inside jacket of the throttle cable? thanks, dr Attached image(s) |
lapuwali |
Sep 15 2004, 04:04 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Aircooled.net sells little springs that go on the carbs themselves right at the throttle arms, and are good backup if your main tension spring breaks. I used those, and a simple tension spring between the arm and one of the trunk springs. Not too heavy, and three springs have to break for me to have stuck open throttles.
Lo-Fi Version | Time is now: 10th June 2024 - 03:58 AM |
