V8 Fuel pump? |
V8 Fuel pump? |
rey |
Sep 15 2004, 04:10 PM
Member Group: Members Posts: 97 Joined: 2-July 04 From: alviso,ca Member No.: 2,285 |
Hi All, another question,
1...... which electric fuel pump do you use with a v8 ? 2......Dose it need a fuel regulator? what psi dose it need to run at? 3....Or can a stock fuel pump be used with the RH or DH set up? Need advise here gentlemen starting to drop some dead presidents need to get the right stuff Thanks (IMG:style_emoticons/default/pray.gif) |
BIGKAT_83 |
Sep 15 2004, 06:01 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I saw on the pelican site that you were interested in a electric water pump. If you use a electric water pump you can use the stock SBC mechanical fuel pump. as long as you mount the alternator on the divers side.
The stock fuel pumps run around $15 at flaps |
Lo-Fi Version | Time is now: 5th June 2024 - 08:56 AM |
