17" vs 15" wheels pros and cons |
moggy |
Aug 23 2015, 01:15 PM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
I don't seem to see many 914 circuit racers with 17" wheels on. Everyone seems to stick to 15". Is there a reason for this? I'm less bothered about the looks of 17" vs 15", I'm more interested in this from a performance perspective. Who out there has tried both wheel sizes? what size did you decide on, and why?
I personally have 15" (Cookie cutters 7" wide all around) (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1440357310.1.jpg) and 17" (Cup1 7"front 9"back) (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1440357310.2.jpg) At the moment, I'm forced to use the 17" on tracks where I need the top speed, due to my low ratio gearbox (a hangup from when it was a rally car). The 17" wheels have a 26" overall diameter. Whereas the 15" wheels are used on slower, twisty tracks. There is a huge weight difference between the wheels (including tyres) of 32kg (70.5lbs) total, which is an obvious benefit to sticking to the 15 "cookie cutters. But weight can't be the only reason why you circuit racers stick with the 15", so what are your reasons? |
john914somers |
Aug 24 2015, 12:52 AM
Member Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California |
I've been on 17" twists but was thinking about going to 15" merely for the weight and smaller diameter options. An old racer told me that I would be going backwards if I did that and that everybody generally needs to go to something bigger than 15" because of the fitment of bigger brakes. I have a 3.6 and a 915 so I'm probably heavier than most guys and the speeds I'm running I think bigger brakes are a must. I did pick up some 15" Wheels and they don't clear my rotars. Consequently I'm back to looking for some lighter 17's and even considering some 18's but I'm not certain they will fit??? Can someone chime in on 18" fitment? Thanks!
JPIII |
Aug 24 2015, 10:51 AM
Newbie Group: Members Posts: 49 Joined: 5-July 15 From: Vancouver, WA. Member No.: 18,919 Region Association: None |
I've been on 17" twists but was thinking about going to 15" merely for the weight and smaller diameter options. An old racer told me that I would be going backwards if I did that and that everybody generally needs to go to something bigger than 15" because of the fitment of bigger brakes. I have a 3.6 and a 915 so I'm probably heavier than most guys and the speeds I'm running I think bigger brakes are a must. I did pick up some 15" Wheels and they don't clear my rotars. Consequently I'm back to looking for some lighter 17's and even considering some 18's but I'm not certain they will fit??? Can someone chime in on 18" fitment? Thanks! My 914 weighed in at 1700 lbs. with a 2.7L. It was an AXer. I did consider going to SMALLER rotors rather than the early 911 set up in place. But it was not worth the hassle and need ballast to make XP weight. The brakes were much under worked. Stock 911 street pads & rotors. I ran it in a DE at about 2100 lbs and they got to stinkin' a bit. but worked fine. The lower of smaller (height) is good for CG. I don't know what you use your 914 for. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:50 PM |
