Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
stugray |
Aug 27 2015, 11:22 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Stupid question, but why cant I see a E-brake lever arm in the pic?
I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:56 PM |
