1972 1.7 not starting |
ctkellett |
Aug 27 2015, 10:22 AM
Newbie Group: Members Posts: 12 Joined: 18-February 15 From: PA Member No.: 18,450 Region Association: None |
I bought a stock running project car with a bad tail shift transmission. I pulled the motor and replaced the transmission with a freshly rebuilt side shift unit from 914 LTD.
After the reinstall I am not able to get the car running again. Things that I have double checked -Fuel Pump runs and primes when the ignition gets switched on at the key -confirmed spark at the coil and at the plug with motor cranks -can hear the injectors pump once while the fuel pump is priming and when you step on the gas pedal once. -confirm that the timing is set correctly, that the points are gapped correctly. - the car will run briefly on starter fluid. Any thoughts? Maybe and ECU issue? Where do the injectors get the signal to fire? Thanks! |
Tom |
Aug 27 2015, 12:23 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Double check that you don't have the fuel lines reversed. Seen this too many times.
Tom |
ctkellett |
Aug 27 2015, 01:03 PM
Double check that you don't have the fuel lines reversed. Seen this too many times. Tom Thanks, I will double check this one. I figured that grounds on the injectors were good if they fired when I stepped on the gas after the fuel pump primed but I will triple check that just incase. |
Lo-Fi Version | Time is now: 28th May 2024 - 11:13 PM |
