Warped rotor?, Have now confirmed it's warped. |
john77 |
Aug 8 2015, 03:28 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
About a month ago something in the rear of my car started making this high-pitched squeaking, metal on metal noise when I was reversing. Not constantly, but like something turning was binding and releasing, binding and releasing. I only had the rear bearings replaced 6 months ago, so i hoped it wasn't that.
With the car up on stands and the rear wheels removed I've isolated it to the driver's side rear wheel. If I turn the rotor by hand it rotates freely and then gets really hard to rotate, and then gets easy, and so on. My first guess is that somehow I've warped the rotor. Does that sound right? I've never tracked the car, but I do ax it. Or could it be something else? I have the 5 lug conversion, so I believe they're off a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1439069310.1.jpg) |
stugray |
Aug 27 2015, 11:22 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Stupid question, but why cant I see a E-brake lever arm in the pic?
I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. |
john77 |
Aug 27 2015, 12:27 PM
Stupid question, but why cant I see a E-brake lever arm in the pic? I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. They're rear 911 m-calipers, so no e-brake. Sorry, completely forgot I asked about the calipers in another thread, not this one. (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1440700511.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i2.photobucket.com-17027-1440700511.2.jpg) |
stugray |
Aug 27 2015, 01:14 PM
Stupid question, but why cant I see a E-brake lever arm in the pic? I dont see the cover for the outer adjuster screw either. Rears requires you to turn the adjuster screw to retract the pistons. From the limited pics those look like front calipers. They're rear 911 m-calipers, so no e-brake. Sorry, completely forgot I asked about the calipers in another thread, not this one. Then you should be able to get the pistons to move using a small C-clamp. I just rebuilt a bunch of 914 Early front calipers to install on my race car in the rear. It is very simple and if you dont feel the need to replate (or paint) the calipers, you can rebuild a pair in an afternoon. It takes longer to take them apart and get the pistons out then to put the new parts in and put them back on the car. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:16 PM |
