Time to move on, Where to start??? |
catsltd |
Aug 28 2015, 07:49 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Got the car running tip top.
Replaced coil,plugs.injectors,old rubber hoses,etc. Now I am down to my biggest remaining problem:Oil Leaks. When I had the car in to shop getting fucked up,they told me these were the areas that had leaks. Rear Main seal. Oil leaking from head(cylinder seal),I am assuming head gasket. Differential side seals.(Probably NOT RELATED???). The car is running great,but it is loosing a lot of oil through these leaks. Questions: 1.Can I fix these thing without removing the engine???(This is the last thing I want to do). 2. Where do I start. Thanks for any suggestions. Grant. |
catsltd |
Aug 28 2015, 04:24 PM
I have no confidence in the company that told me where my oil leaks are located.
So I will clean the motor and tranny of all oil,and then watch to see where it is dripping down from. I told the shop I was going through a lot of oil,they said its time for a rebuild. I suggested I should fix all my oil leaks before I decide on whether or not I need my motor rebuilt. Anyway Im off work Sunday so Ill get some pictures. Thanks for all the suggestions,but I better find out exactly what is leaking before I figure out whether I can do it without dropping the motor. Thanks. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:26 AM |
