Seabird |
Member ![]() ![]() Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States ![]() |
Looks like I am in the engine rebuilding way at the moment. Finally got feed up with trying to figure out what was wrong with my engine/auxiliary systems so I pulled the motor this weekend.
Probably the last time out on track the motor dropped a valve guide. Found one broken secondary spring. And I still haven't pulled the driver side head! Fun fun. Ideally I would like to find quality 95mm pistons (allowed a 1.2mm over bore for the class I am preparing to run) and machine my cylinders to match. There does not seem to be a quality 95mm option on the shelf. (I know AA makes a 95mm piston & cylinder set; I am just not interested in buying it.) My question is: has anyone ordered custom 95mm JE pistons and are willing to share the part number? Alternatively is there a source for forged 94mm flat top pistons? All the forged pistons I can find are 96mm or bigger. Thanks, Miguel |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Slightly still on topic:
Where can you get a NEW FORGED crank with the stock 71mm Stroke? (other than that NOS 2.0L crank I saw recently for $3000) I see lots of new forged cranks (like at scat), but they are all for stroker motors. If you want NEW & Stock stroke, it seems you are stuck with billet. |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
Slightly still on topic: Where can you get a NEW FORGED crank with the stock 71mm Stroke? (other than that NOS 2.0L crank I saw recently for $3000) I see lots of new forged cranks (like at scat), but they are all for stroker motors. If you want NEW & Stock stroke, it seems you are stuck with billet. The factory cranks are forged, chilled German steel. Not likely to find a better crank material. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:24 AM |
