V8 Fuel pump? |
V8 Fuel pump? |
rey |
Sep 15 2004, 04:10 PM
Member Group: Members Posts: 97 Joined: 2-July 04 From: alviso,ca Member No.: 2,285 |
Hi All, another question,
1...... which electric fuel pump do you use with a v8 ? 2......Dose it need a fuel regulator? what psi dose it need to run at? 3....Or can a stock fuel pump be used with the RH or DH set up? Need advise here gentlemen starting to drop some dead presidents need to get the right stuff Thanks (IMG:style_emoticons/default/pray.gif) |
mayord2001 |
Sep 16 2004, 07:25 AM
Newbie Group: Members Posts: 4 Joined: 9-October 03 From: monroe, ga. Member No.: 1,231 |
I've used a Carter for years w/ 350 Chevy w/ Holley and w/Qjet. Never had any problems even though mine is mounted in the engine bay. However, I recommend mounting near tank. Any of the other basic pumps will work as well. Some are noisier than others. Finally, I think it is a good idea to incorporate a pressure switch into the circuit for safety reasons.
Lo-Fi Version | Time is now: 31st May 2024 - 08:43 PM |
