done fuming, d.a tech person |
rhodyguy |
Sep 15 2004, 03:18 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
my car rode rough and cornered like... well less than i expected after the first suspension upgrade. every expansion joint a pita, lliterally. i thought it was just the koni and mild rear spring. specificly AFTER the big fancy alignment and corner balance at a "race shop" in bellevue. well shit. it came back low all right. the adjusters are tuned down to the point where is 1/2 of 1 complete thread showing on the top portion.
b mentioned some time ago about a members car riding on the rubber snubbers/cushions on the fronts. well mine were too. to the point where the bottom ring was collasped, as in partialy shoved up inside of the next ring. so my konis were not working at all, the only, "work", i had going on was the COMPRESSION of the snubbers inside of each other. now it gets even better, or worse depending what side of the computer screen you are on. i purchased some mono balls from triad when i was doing the front end. there is supposed to be a sleeve type affair that slides up from the bottom securing the strut rod in the monoball. well that f-er wasn't there either. i only started with the drivers side. no point in putting back together WITH OUT ALL OF THE DAMN PARTS!! i didn't drop or misplace it. the fool didn't not put it in. well i know i'm going to have raise the front end a bit. how could it have truly been balanced whe the car was sitting on the hard on the front. i've just about had enough. AARRGGHH!!! another alingment is in the works. f me to tears. i'm going to break down and have a becks kevin |
mike_the_man |
Sep 16 2004, 09:05 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
QUOTE(F4i @ Sep 15 2004, 08:30 PM) Anybody know of a good alignment shop in Calgary? This sounds like a road I do not want to go down. (IMG:style_emoticons/default/unsure.gif) Dylan, I'm in the same boat you are. It shouldn't be too bad finding a place in Calgary, but finding somewhere in Regina is pretty tough. I took my car to what was supposed to be "the place" for alignments. I gave him the specs that I wanted the car aligned to, front and rear. I left my cell number and told them to call if there were any questions or issues. A couple hours later I stop in to pick it up. All that had been adjusted was the toe. The wrench says that there isn't enough adjustment to do the camber and caster ( a lie). He also told me that the rear isn't adjustable, I told him it was. So he starts back tracking and tells me I never told him to do the rear. When looking at the specs, the rear toe was positive on one side, and negative on the other! Why wouldn't I want that fixed?!? I figure he had no idea what he was doing, and he was just trying to hide his incompetence. So, I understand the frustration. I'd call and complain. Have them redo it for free, while you stand over the guys shoulder. |
Lo-Fi Version | Time is now: 4th June 2024 - 11:10 PM |
