| andys |
Sep 6 2015, 05:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
The driver side headlight on my '75 914 won't go down when the switch is turned off. I tried probing around and found I can get it to go down by lightly pushing on the black sleeving that covers the green wire. I thought, ok, must be a broken wire, or a broken solder joint. I cut away the sleeving and I see what looks to be a capacitor (?).
I the accompanying photo, if I push on the capacitor lead adjacent to the motor terminal, I get nothing. If I push on the capacitor lead at the green wire, I get nothing. However, if I push on the capacitor lead close to its (black) body at the one o'clock side, the light goes down. I get nothing pushing on the seven o'clock side. Damaged capacitor perhaps? I have a set of motors from a '72 or '73 (don't know if they work), but will I find the same capacitor under their sleeving? Would I be better off buying a new capacitor from the electronics supply? Does anyone know the value of the capacitor? Thanks, Andys Attached thumbnail(s) |
| Mike Bellis |
Sep 7 2015, 01:18 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
| andys |
Sep 7 2015, 02:19 PM
Mike, Thanks for the manual page. I see two capacitors on each motor at 30b and K, but I wonder what are their values? Andys |
| era vulgaris |
Sep 7 2015, 02:34 PM
J is for Genius ![]() ![]() ![]() Group: Members Posts: 987 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Mike, Thanks for the manual page. I see two capacitors on each motor at 30b and K, but I wonder what are their values? Andys You see two diodes on each motor. This is a diode symbol: Attached image(s)
andys Headlight Won't Go Down Sep 6 2015, 05:18 PM
The Cabinetmaker I've removed many headlight assemblies. Never ... Sep 6 2015, 05:22 PM
era vulgaris That looks like a diode, but it's tough to tel... Sep 6 2015, 06:12 PM
Maltese Falcon Agreed, not a capacitor. Just out of curiosity hav... Sep 6 2015, 07:43 PM
andys Era Vulgaris,
That's as good a photo as I cou... Sep 7 2015, 12:22 PM
steuspeed I see 4 diodes :confused: Sep 7 2015, 02:22 PM
Old Yella I had the same problem. It had nothing to do with ... Sep 7 2015, 02:42 PM
andys Ooops, Yeah I mean diodes!
Anyone care to tak... Sep 7 2015, 02:43 PM
era vulgaris
Anyone care to ta... Sep 7 2015, 03:15 PM
era vulgaris On a side note that has nothing to do with the OP,... Sep 7 2015, 03:19 PM
jim_hoyland Old thread, but I have the exact same problem; any... Sep 11 2017, 12:43 PM
914Wiggy
Old thread, but I have the exact same problem; an... Aug 19 2018, 01:27 PM
jim_hoyland
Old thread, but I have the exact same problem; a... Aug 19 2018, 03:43 PM
sb914 Watch your fingers! Aug 19 2018, 04:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th November 2026 - 12:56 AM |
