| bob91403 |
Sep 17 2004, 02:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
Could someone tell me why a scoop can't increase air pressure, as you go faster, and create the same kind of HP "boost" you get from turbo or superchargers? Excuse me for being ignorant. But, isn't it just a matter of increasing air pressure to the intake, and pumping in the right amount of gas for mixture? What about a pressurized tank of air, or both air and propane tanks? Couldn't you use a small compressor for boost, or as a source to refill a "boost" tank? I really don't understand this obcession with tubocharging. Nitrous systems have been around for a long time, and are much simpler. I was told, by my top rated Porsche mechanic, that, "Yeah, higher compression heads, turbocharging, supercharging, nitrous oxide, will all increase horsepower. But, anything you do to increase the horsepower will seriously lower the longevity of the engine." He doesn't even recomend european compression heads for a rebuild. I do understand, tubocharging a smaller engine gives you increased horsepower, plus the weight advantage of not having to put in a 3.2L six. But, if you have to rebuild it every 50K, instead of 150K miles, doesn't conversion cost less? Curious to hear your replies.
| bob91403 |
Sep 17 2004, 04:53 AM
QUOTE(redshift @ Sep 17 2004, 01:41 AM) A rebuilt 2.0 cost $6,000.00, a rebuilt 3.2 cost more than twice that. To convert a 2.0 to a turbo, you need a turbo, a shoestring, and some PVC. To use nice parts, it's going to cost you more than a 2.0 rebuild to modify the car for a 3.2 You can't use a scoop to 'turbo' your car, because you'd have to be going about 300 miles per hour, and have a very odd tube that is shaped like a trumpet, with a 5' mouth, and 18' long on top of your car to collect the air. Nitrous is for somebody else, we aren't drag racers. (IMG:style_emoticons/default/smile.gif) Superchargers are rare around here, when you find one, let me know. M All these "boost" references are in pounds. I know NA is 1 atm. How many atms does a turbo achieve? And, wouldn't it need an equal amount of fuel for the mix? i.e 2atm = twice as much gas? |
bob91403 Forced Air? TURBO? Sep 17 2004, 02:56 AM
redshift A rebuilt 2.0 cost $6,000.00, a rebuilt 3.2 c... Sep 17 2004, 03:41 AM
bob91403 ... Sep 17 2004, 04:44 AM
SLITS NAP is 14.7 lbs (sea level). A turbo, in theory, ... Sep 17 2004, 10:27 AM
airsix
soloracer For increased power you need to increase both the ... Sep 17 2004, 11:16 AM
lapuwali A properly placed and ducted scoop would raise the... Sep 17 2004, 11:28 AM
airsix ... Sep 17 2004, 12:25 PM
SLITS They all mean the same thing, so what's the pr... Sep 17 2004, 12:45 PM
lapuwali No problem from me. Some people get rather, um, a... Sep 17 2004, 01:00 PM
airsix
phantom914
SpecialK I prefer a less restrictive method of measurement.... Sep 17 2004, 03:39 PM
redshift ... Sep 17 2004, 06:04 PM
bob91403
mike_the_man I can't remember for sure, but I think there h... Sep 17 2004, 10:03 PM
Red-Beard 6K for a 3.2 6cyl, purchase plus a no BS rebuild. ... Sep 17 2004, 10:05 PM
Qarl
Red-Beard It didn't cost me $1.5K to have my 911 he... Sep 18 2004, 10:27 AM
Sammy Are those type 1 engines or type 4? My guess is ty... Sep 18 2004, 10:36 AM
914_1.8t I don't see why it would be so difficult to tu... Sep 18 2004, 12:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 11:14 AM |
