2200rpm idle & stumbles around 3200 when driving, making progress, idle down to 1100, still stumbles above 3k |
RazorbackFan78 |
Sep 8 2015, 06:30 PM
3 different layers of paint helps protect if from rust Group: Members Posts: 136 Joined: 29-March 13 From: Bentonville, AR Member No.: 15,709 Region Association: South East States |
Hey guys - I'm trying to track down the cause of my high idle.
I've checked the TPS and I get 20 clicks pre-ignition I've pulled the AAR, soaked it in PBlaster, froze it, put 12v through it, confirming it opens and closes correctly. It also tested around 17ohms I cleaned grounds at headlights, battery neg, driverside engine bay, and visually confirmed trans strap is brand spankin' new (thanks Curt) Now i'm checking hoses for vac leaks and only one seems to drop the idle (drops it to a steady 1100rpm). It's the hose from the airbox elbow that Y's into the AAR and dizzy. See picture. Is this sounding like my dizzy could use a good cleaning? I have other items on my troubleshooting list like MPS, fuel filter and decel valve but wanted to check in with you guys after discovering the vac issue. Thanks for your input. I'm still fairly new to this type of engine....so I'm learning as I go (IMG:style_emoticons/default/biggrin.gif) BACKSTORY: for those of you who like a novel....car had points and idle would bounce between 100-900rpm more often than not. Anytime I'd reach 3200rpm while driving it would studder and loose power, in all gears, and it would also occasionally do it under a heavy foot at lower rpms. I replaced points with Pertronix 1847V and now the cold idle sits on 1100 like a rock for the first minute or so, then over the next minute it climbs to 2200 and holds steady. It still studders around 3200 when driving and occasionally does it at lower rpms when I'm really on the pedal. Attached image(s) |
913B |
Sep 15 2015, 10:58 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
For those of you still following this thread, my problem appears to be SOLVED!!!! Wouldn't ya know it Curt, my timing was out of adjustment (smack forehead). In the future, I'll start with that as #1 on my checklist Pulls nice and strong all the way to 5k now. Time to start taking longer joy rides to prove she's ready to take to my first 914World event (IMG:style_emoticons/default/aktion035.gif) Thanks everyone! Would it possible to provide the steps you took to check the timing. I just want to make sure i am doing it right Thanks in advance Ted |
RazorbackFan78 |
Sep 16 2015, 07:19 AM
For those of you still following this thread, my problem appears to be SOLVED!!!! Wouldn't ya know it Curt, my timing was out of adjustment (smack forehead). In the future, I'll start with that as #1 on my checklist Pulls nice and strong all the way to 5k now. Time to start taking longer joy rides to prove she's ready to take to my first 914World event (IMG:style_emoticons/default/aktion035.gif) Thanks everyone! Would it possible to provide the steps you took to check the timing. I just want to make sure i am doing it right Thanks in advance Ted Ted - I just followed the Timing instructions over on the Pelican site. Here's the link It's pretty straight fwd but it was a little tricky trying to do it without a second pair of hands and eyes...specifically when you're trying to find the TDC mark on your fan and then later when you have to do three things at once: hold rpm's at 3500 AND hold the timing gun AND rotate the distributor all at the same time. Oh and taking a tip from one of the other members, definitely take a paint brush and mark your TDC and your 27deg positions on both edges of the fan so you don't have to keep using a mirror to look backwards into the fan viewing hole (IMG:style_emoticons/default/biggrin.gif) Oh and definitely paint the two lines different colors. I used white metallic Testors model paint for my 27deg mark since it really stands out when the timing light hits it. Best of luck! |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:01 PM |
