> Compression Test, PC- An exercise in mental masturbation
SLITS
post Sep 17 2004, 05:45 PM
"This Utah shit is HARSH!"
Scenerio: You buy an engine and do a compression test. Cylinders measure 135, 130, 130 & 85 - BUMMER. So, since this engine has not run in upteen years, you throw it on the lift and pull the valve cover on the 3/4 side (#4 cyl is the low one).
Lo and behold, you notice that the #4 exhaust valve rocker has no adjuster screw or lock nut and there is a v-shaped piece of aluminum missing from the rocker box beneath the #4 intake valve. Futher probing (Aaron would like that) with a magnet reveals the missing parts.
Great story, but not the point of the post.
Problem:
If the exhaust valve is not opening to relieve the pressure, allowing kinetic energy to pull a larger charge of air into the cylinder when the intake opens, it will not build cylinder pressure like a normal compression test of a cylinder that is working. This is my theory anyway.
I have already been told by one mechanic that I am full of shit and another that agrees with me. No I haven't redone the compression test since replacing the screw and locknut.
This is your chance to mentally masturbate and tell me if I am full of feces or not! Spew away.
- Lo-Fi Version Time is now: 1st August 2025 - 03:46 PM
