SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Scenerio: You buy an engine and do a compression test. Cylinders measure 135, 130, 130 & 85 - BUMMER. So, since this engine has not run in upteen years, you throw it on the lift and pull the valve cover on the 3/4 side (#4 cyl is the low one).
Lo and behold, you notice that the #4 exhaust valve rocker has no adjuster screw or lock nut and there is a v-shaped piece of aluminum missing from the rocker box beneath the #4 intake valve. Futher probing (Aaron would like that) with a magnet reveals the missing parts. Great story, but not the point of the post. Problem: If the exhaust valve is not opening to relieve the pressure, allowing kinetic energy to pull a larger charge of air into the cylinder when the intake opens, it will not build cylinder pressure like a normal compression test of a cylinder that is working. This is my theory anyway. I have already been told by one mechanic that I am full of shit and another that agrees with me. No I haven't redone the compression test since replacing the screw and locknut. This is your chance to mentally masturbate and tell me if I am full of feces or not! Spew away. |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
QUOTE(SLITS @ Sep 17 2004, 04:04 PM) Not sure of anything - like I said, it is an exercise that I can't prove until I do another compression test. The rest of the theory would be that since the cylinder is already pressurized, at overlap the pressure would be released into the intake tract (much like a reversion wave) decreasing the intake charge volume. Hey, I had nothing better to do than think of this or I could go back to hijacking threads. (IMG:style_emoticons/default/laugh.gif) Could be. But just doesn't seem like it would make as much difference as you're seeing. Don't forget also that at cranking speeds, the inertia of air is not near the factor it is at running speeds, so reversion and scavenging may not mean anything. But who knows? Let us know what the 'after' results are. Andrew |
Lo-Fi Version | Time is now: 1st August 2025 - 03:48 PM |
