| 913B |
Sep 18 2015, 10:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
I am checking the valves because they seem noisy and also to track down an erratic idle
I have read the rocking method but I would like to stick with the dizzy and TDC method please. I read cyl #1 & #3 has same TDC and #2 & #4 has same TDC Question 1 – Setting TDC on the fan notch does it have to be at “0” or will the notch for “27BTDC” work too When I find TDC for #1 on fan notch and dizzy rotor is pointing to #1 tower of dizzy cap Question 2 - Can I adjust all the valves for #1 and #3 cyl ?? Then rotating the motor to #2 TDC on fan notch and dizzy is pointing to #2 tower Question 3. Can I adjust all the valves for #2 and #4 cyl ?? Question 4. Is it wise to replace the cork valve cover and not risk a leak. The gasket is pretty new though and low mileage since I last had them off. I am thinking of purchasing the 914rubber re-usable ones. Any recommendation’s Thanks everyone ! Ted |
| TheCabinetmaker |
Sep 19 2015, 02:26 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You have to make a mark on the flywheel. While under the car, reach up around the trans and find the top hole like the bottom one. Rotate flywheel till you can feel the notch with your fingertip. Put some white paint on the flywheel thru the bottom hole. The engine is at either 1 or 3 when you can see the paint. 2 or 4 when the notch is visible. The crankshaft rotates twice for every engine revolution. I'm not sure cause I haven't adjusted valves in a while, but I think your turning the wheel the wrong direction
porsche913b_sp Adjusting the valves, quick and short questions. Sep 18 2015, 10:36 AM
dangrouche http://www.914world.com/bbs2/index.php?showtopic=2... Sep 18 2015, 11:07 AM
stugray If you have never done it before, I suggest you do... Sep 18 2015, 04:32 PM
r_towle The camshaft shares the same lobe for the two valv... Sep 18 2015, 05:33 PM
Dave_Darling I use the "book" method, which means set... Sep 18 2015, 06:29 PM
stugray I agree that "the crusty method" is the ... Sep 18 2015, 10:49 PM
porsche913b_sp Can someone please confirm I am doing this right.
... Sep 19 2015, 01:08 PM
era vulgaris
Another odd thing the valve cover on drivers sid... Sep 20 2015, 07:10 AM
stugray Did you check the video link I posted above?
For ... Sep 19 2015, 03:13 PM
Steve Pratel Good Lord this is giving me agita........... I... Sep 19 2015, 03:39 PM
The Cabinetmaker Hey Steve, I think you mean angina. Lol. Don't... Sep 19 2015, 04:59 PM
Steve Pratel
Hey Steve, I think you mean angina. Lol. Don... Sep 19 2015, 10:14 PM
porsche913b_sp Thanks for all the help everyone.
I lined up the ... Sep 19 2015, 10:38 PM
stugray
How do I time it using the notch on the top, do ... Sep 19 2015, 11:00 PM
porsche913b_sp So why is it that the marks on the fan is off and ... Sep 19 2015, 11:53 PM
Dave_Darling
So why is it that the marks on the fan is off and... Sep 20 2015, 04:42 PM
The Cabinetmaker I've read the upside down thing so many times.... Sep 20 2015, 12:59 PM
theleschyouknow thought read somewhere about the type -4s being or... Sep 20 2015, 01:29 PM
The Cabinetmaker Buses have engine tin too. Sep 20 2015, 01:31 PM
The Cabinetmaker How's the red dog, cj? What breed is she? I fo... Sep 20 2015, 01:33 PM
theleschyouknow ahh.... the tin
ah so
maybe initially installed by... Sep 20 2015, 02:16 PM
The Cabinetmaker He's not crazy, just very alert. Sep 20 2015, 03:48 PM
The Cabinetmaker Damn it. I did it again. Sep 20 2015, 03:58 PM
theleschyouknow :beer2:
I had a pic of him in that reply but it w... Sep 20 2015, 04:07 PM
era vulgaris Cap'n Krusty always said that the tab that sti... Sep 20 2015, 04:29 PM
hedfurst 1. All 4 cylinder ACVW motors have the same basic ... Sep 20 2015, 04:51 PM
porsche913b_sp Ok the valve adjustment is done now trying to time... Sep 26 2015, 02:33 PM
porsche913b_sp Update:
I can sort of get idle to come to 900 but ... Sep 26 2015, 03:06 PM
The Cabinetmaker Timing light clamp on #1? That's drivers side ... Sep 26 2015, 03:57 PM
porsche913b_sp Yes timing light clamp on #1 plug wire Sep 26 2015, 04:49 PM
stugray check to make sure the advance mechanism in the di... Sep 27 2015, 10:20 AM
porsche913b_sp I checked advance and retard with mity vac and the... Sep 27 2015, 11:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:37 AM |
