> Adjusting the valves, quick and short questions., NOW I need help on timing !!!! PLEASE
913B
post Sep 18 2015, 10:36 AM
I am checking the valves because they seem noisy and also to track down an erratic idle
I have read the rocking method but I would like to stick with the dizzy and TDC method please.
I read cyl #1 & #3 has same TDC and #2 & #4 has same TDC
Question 1 – Setting TDC on the fan notch does it have to be at “0” or will the notch for “27BTDC” work too
When I find TDC for #1 on fan notch and dizzy rotor is pointing to #1 tower of dizzy cap
Question 2 - Can I adjust all the valves for #1 and #3 cyl ??
Then rotating the motor to #2 TDC on fan notch and dizzy is pointing to #2 tower
Question 3. Can I adjust all the valves for #2 and #4 cyl ??
Question 4. Is it wise to replace the cork valve cover and not risk a leak.
The gasket is pretty new though and low mileage since I last had them off.
I am thinking of purchasing the 914rubber re-usable ones. Any recommendation’s
Thanks everyone !
Ted
era vulgaris
post Sep 20 2015, 04:29 PM
J is for Genius
Cap'n Krusty always said that the tab that sticks off of the one end of the cover is supposed to be on the bottom, which would put the VW logo upside down. He never said why though, at least not in any thread I've ever come across.
I've read that other people have said that even though the cover looks symmetrical, it actually isn't. I've never looked closely enough to say if that's true or not.
But yeah, I've never come across anything that says exactly why. There must be SOME reason for that tab one the one end, if not just to be there for a directional indicator. (IMG:style_emoticons/default/confused24.gif)
porsche913b_sp   Adjusting the valves, quick and short questions.   Sep 18 2015, 10:36 AM
dangrouche   http://www.914world.com/bbs2/index.php?showtopic=2...   Sep 18 2015, 11:07 AM
stugray   If you have never done it before, I suggest you do...   Sep 18 2015, 04:32 PM
r_towle   The camshaft shares the same lobe for the two valv...   Sep 18 2015, 05:33 PM
Dave_Darling   I use the "book" method, which means set...   Sep 18 2015, 06:29 PM
stugray   I agree that "the crusty method" is the ...   Sep 18 2015, 10:49 PM
porsche913b_sp   Can someone please confirm I am doing this right. ...   Sep 19 2015, 01:08 PM
era vulgaris   Another odd thing the valve cover on drivers sid...   Sep 20 2015, 07:10 AM
The Cabinetmaker   You have to make a mark on the flywheel. While und...   Sep 19 2015, 02:26 PM
stugray   Did you check the video link I posted above? For ...   Sep 19 2015, 03:13 PM
Steve Pratel   Good Lord this is giving me agita........... I...   Sep 19 2015, 03:39 PM
The Cabinetmaker   Hey Steve, I think you mean angina. Lol. Don't...   Sep 19 2015, 04:59 PM
Steve Pratel   Hey Steve, I think you mean angina. Lol. Don...   Sep 19 2015, 10:14 PM
porsche913b_sp   Thanks for all the help everyone. I lined up the ...   Sep 19 2015, 10:38 PM
stugray   How do I time it using the notch on the top, do ...   Sep 19 2015, 11:00 PM
porsche913b_sp   So why is it that the marks on the fan is off and ...   Sep 19 2015, 11:53 PM
Dave_Darling   So why is it that the marks on the fan is off and...   Sep 20 2015, 04:42 PM
The Cabinetmaker   I've read the upside down thing so many times....   Sep 20 2015, 12:59 PM
theleschyouknow   thought read somewhere about the type -4s being or...   Sep 20 2015, 01:29 PM
The Cabinetmaker   Buses have engine tin too.   Sep 20 2015, 01:31 PM
The Cabinetmaker   How's the red dog, cj? What breed is she? I fo...   Sep 20 2015, 01:33 PM
theleschyouknow   ahh.... the tin ah so maybe initially installed by...   Sep 20 2015, 02:16 PM
The Cabinetmaker   He's not crazy, just very alert.   Sep 20 2015, 03:48 PM
The Cabinetmaker   Damn it. I did it again.   Sep 20 2015, 03:58 PM
theleschyouknow   :beer2: I had a pic of him in that reply but it w...   Sep 20 2015, 04:07 PM
era vulgaris   Cap'n Krusty always said that the tab that sti...   Sep 20 2015, 04:29 PM
hedfurst   1. All 4 cylinder ACVW motors have the same basic ...   Sep 20 2015, 04:51 PM
porsche913b_sp   Ok the valve adjustment is done now trying to time...   Sep 26 2015, 02:33 PM
porsche913b_sp   Update: I can sort of get idle to come to 900 but ...   Sep 26 2015, 03:06 PM
The Cabinetmaker   Timing light clamp on #1? That's drivers side ...   Sep 26 2015, 03:57 PM
porsche913b_sp   Yes timing light clamp on #1 plug wire   Sep 26 2015, 04:49 PM
stugray   check to make sure the advance mechanism in the di...   Sep 27 2015, 10:20 AM
porsche913b_sp   I checked advance and retard with mity vac and the...   Sep 27 2015, 11:15 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:11 PM
