> Painting inside the doors., What did you do?
Olympic 914
post Sep 22 2015, 07:13 AM
Considering getting my doors media blasted, probably soda blast. and was wondering how did any of you guys paint the inside of the doors?
can't really get a spray gun in there. I used some of the Eastwood inner frame coating inside the longs and the tunnel, but the inside of the doors will get water from rain and wash water running down into them. I think they will need something more substantial inside.
I guess I could just get in there with a paint brush and go to town
I have used Rust Bullet on the inner fenders and underside after sanding and sandblasting. this would probably work inside the doors also.
What have you used?
I have doors without the safety bars and there is a tar like coating inside, hopefully the media blast will remove it. it will be a PITA to scrape it out I think.
Also would you recommend putting something like dyna mat in there or spraying a coating like Rhino liner inside to cut down on noise and add protection ? Not a racer so weight isn't important.
I haven't taken them apart yet.
screenguy914
post Sep 22 2015, 11:47 AM
Once bare metal is exposed, use POR 21 or equivalent to prevent rust from forming, especially at the bottom of the door. Many of these products now come in a rattle can format. You can follow up with paint top coats, undercoating and/or sheets of DynaMat or equivalent for noise attenuation.
Sherwood
- Lo-Fi Version Time is now: 2nd April 2026 - 09:44 AM
