| Olympic 914 |
Sep 22 2015, 07:13 AM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Considering getting my doors media blasted, probably soda blast. and was wondering how did any of you guys paint the inside of the doors?
can't really get a spray gun in there. I used some of the Eastwood inner frame coating inside the longs and the tunnel, but the inside of the doors will get water from rain and wash water running down into them. I think they will need something more substantial inside. I guess I could just get in there with a paint brush and go to town I have used Rust Bullet on the inner fenders and underside after sanding and sandblasting. this would probably work inside the doors also. What have you used? I have doors without the safety bars and there is a tar like coating inside, hopefully the media blast will remove it. it will be a PITA to scrape it out I think. Also would you recommend putting something like dyna mat in there or spraying a coating like Rhino liner inside to cut down on noise and add protection ? Not a racer so weight isn't important. I haven't taken them apart yet. |
| whatabout1 |
Sep 23 2015, 01:40 PM
Toys in Red ![]() ![]() Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None |
Yea, you can get in there.
Cleaning the inside was a major PITA !!! There were some big chunks of body putty that had no purpose. Getting way down in corners was a challenge (IMG:style_emoticons/default/ar15.gif) After sealing everything inside with Eastwood rust converter, I brushed a healthy coat of truck bed liner in. Edit: Oh yea, make sure you keep the drain holes open ! ![]() |
Olympic 1.7 Painting inside the doors. Sep 22 2015, 07:13 AM
Geezer914 Eastwood rust encapsilator. Sep 22 2015, 11:09 AM
screenguy914 Once bare metal is exposed, use POR 21 or equivale... Sep 22 2015, 11:47 AM
boxsterfan Wouldn't the Dynamat (or similar) just trap wa... Sep 22 2015, 02:51 PM
boxsterfan Hmmmmm.....so maybe I will not go with any Dynamat... Sep 23 2015, 11:30 AM
mepstein Talk to a painter before you start using por produ... Sep 23 2015, 11:33 AM
scotty b
Talk to a painter before you start using por prod... Sep 23 2015, 11:40 AM
boxsterfan
Talk to a painter before you start using por pro... Sep 23 2015, 12:41 PM
Olympic 1.7 Yuck
I was planning on using dynamat on my fire... Sep 23 2015, 11:35 AM
whatabout1 I have used DEI Boom Mat spray on allot of stuff. ... Sep 23 2015, 02:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:10 AM |
