> So I adjusted the valves and..., help out a newbie
danimal
post Sep 18 2004, 06:30 PM
havent had the car for long, it was backfiring so I figured I'd adjust the valves.
Pretty sure I did everything right. I re-checked 4 times. Now it runs ok but it's really loud. I know some valve clatter is ok, but it sounds like a diesel rabbit.
I know it's hard to recreate a sound on a forum post but it sounds like something is pounding.
Is this normal or did I miss something.
tracks914
post Sep 18 2004, 06:44 PM
Canadian Member
Any chatter should go away once the engine is warmed up.
How much clearance did you leave? I leave about .004" on both intake and exhaust.
Did you also rotate the engine and check the cam wear all the way around? I found on one of mine, when I adjusted it at TDC, it was OK but on the opposite side of the cam (as TDC) I had about .004" more wear. This meant my cam was worn unevenly and there isn't much you can do about that but to replace it.
- Lo-Fi Version Time is now: 19th March 2026 - 11:12 PM
