> SSI heat exchanger warning, Carbon monoxide kills!
914ltd
post Oct 6 2011, 06:34 AM
I posted this previously, heating season is here again. These are big cracks, a tiny one you would not be able to hear would still be dangerous. These are not accident damaged. If you have a set on your car, grab the carbon monoxide detector from home and take a ride with the heat on and windows rolled up. There is a detector used in small aircraft also available. The last photo is how we now test for leaks using air pressure. Brad
This post is still relevant today some 15 years since I first posted it. A large number of these early SSI's are still around in parts stashes and yet to be restored 914's. The currently available heats are most likely safe. I have not found anything similar in a stock, even rusty heat exchanger.
STAY SAFE!
Brad Mayeur
Johny Blackstain
post Sep 25 2015, 07:15 PM
QUOTE(Dave_Darling @ Sep 25 2015, 08:19 PM) *
I'm pretty sure that SSI made all of the 914 four-cylinder ones.
--DD
QUOTE(SirAndy @ Sep 25 2015, 09:06 PM) *
QUOTE(Dave_Darling @ Sep 25 2015, 05:19 PM) *
Has the quality of the materials or craftsmanship on the stainless exchangers gone down over the years?
The factory exchangers rusted out after 4 years & nearly killed my Pop from CO poisoning, which is why he bought the stainless ones back in 79.
914ltd   SSI heat exchanger warning   Oct 6 2011, 06:34 AM
mepstein   So just the shell is stainless?   Oct 6 2011, 06:43 AM
914ltd   So just the shell is stainless? Jim The whole h...   Oct 6 2011, 09:04 AM
SLITS   So just the shell is stainless? Jim The whole ...   Oct 6 2011, 09:14 AM
rick 918-S   Thanks Brad! I have seen a set like that. Just...   Oct 6 2011, 06:50 AM
jimkelly   i believe the pipes are stainless too - a magnet s...   Oct 6 2011, 06:51 AM
914ltd   i believe the pipes are stainless too - a magnet ...   Oct 6 2011, 09:22 AM
wingnut86   Just assuming here, but is the washer/rubber dongl...   Oct 6 2011, 07:27 AM
rick 918-S   Just assuming here, but is the washer/rubber dong...   Oct 6 2011, 07:40 AM
VRROOMM1   Just assuming here, but is the washer/rubber dong...   Oct 6 2011, 07:42 AM
76-914   Just assuming here, but is the washer/rubber dong...   Oct 6 2011, 07:47 AM
wingnut86   Great responses. All noted in my broken Carolina ...   Oct 6 2011, 07:52 AM
tradisrad   I've seen a cracked one.   Oct 6 2011, 07:53 AM
dlee6204   This is a great thing to check. Thanks for postin...   Oct 6 2011, 08:16 AM
jaxdream   One way of using this method is to hold each pluge...   Oct 6 2011, 09:31 AM
avidfanjpl   Sounds like we should see if someone is willing to...   Oct 6 2011, 12:11 PM
mepstein   Sounds like we should see if someone is willing t...   Oct 6 2011, 03:12 PM
poorsche914   I had a 1.7 set of SSIs on my 914 and after many a...   Nov 11 2011, 12:21 PM
914ltd   Let me suggest you don't repair the bad SSI...   Nov 11 2011, 01:47 PM
poorsche914   Let me suggest you don't repair the bad SSI...   Nov 11 2011, 03:53 PM
69rsss   Sounds like we should see if someone is willing ...   Nov 18 2011, 12:50 AM
flipb   I've previously gotten oil (from a leak) into ...   Oct 6 2011, 12:21 PM
GeorgeRud   As these cars age, things do wear out. Even thing...   Oct 6 2011, 01:44 PM
RFoulds   if you dont need the heat, simply remove the hose ...   Oct 6 2011, 02:00 PM
ConeDodger   Some where all stainless others were not. I recall...   Oct 6 2011, 02:33 PM
Mikey914   A simple cheap insurance is one of these. You can ...   Nov 11 2011, 12:57 PM
sixnotfour   my daily driver I switched to gas heat, Nice dry c...   Nov 11 2011, 02:04 PM
GeorgeRud   If you have any pictures of your gas heater and it...   Nov 11 2011, 10:32 PM
bigkensteele   I just put my car back together and drove it for t...   Nov 17 2011, 10:10 PM
GeorgeRud   You could get a CO detector card, turn the heat on...   Nov 17 2011, 10:23 PM
bigkensteele   I picked this up at HD Racing today. $28 is ...   Nov 18 2011, 07:00 PM
jaxdream   I picked this up at HD Racing today. $28 is...   Nov 18 2011, 10:58 PM
RobW   Thanks for posting this nugget. We all love our ...   Nov 19 2011, 05:26 AM
nathansnathan   I found something similar on a pair of factory bus...   Nov 19 2011, 10:25 AM
wingnut86   :WTF: Racer Chris's custom headers with heat...   Nov 19 2011, 08:35 PM
partwerks   One less thing for me to worry about having the WR...   Nov 19 2011, 08:49 PM
jimkelly   my first encounter with a sshe that had a crack in...   Mar 15 2012, 04:10 PM
bandjoey   What About the common steel HE's? Do they cra...   Mar 15 2012, 06:43 PM
bigkensteele   Thanks to Brad and this thread, I don't drive ...   Mar 15 2012, 06:57 PM
2xs performance   Great thread! This is my first air-cooled car...   Mar 15 2012, 07:44 PM
sean_v8_914   2013 bump on an important thread   Jul 4 2013, 03:49 PM
michael7810   Thanks for the bump. Today I removed my stock HXs...   Jul 4 2013, 05:11 PM
euro911   I'm back to thinking about electric heaters fo...   Jul 4 2013, 08:29 PM
Mark Henry   I'm back to thinking about electric heaters f...   Jul 5 2013, 07:04 AM
euro911   I'm back to thinking about electric heaters f...   Jul 5 2013, 12:05 PM
Maltese Falcon   Last year Dansk purchased the SSI brand and added ...   Jul 4 2013, 09:53 PM
bigkensteele   $28 O2 sensor that could save your life :be...   Jul 4 2013, 11:37 PM
euro911   Good reviews too.   Jul 5 2013, 01:17 AM
Jgilliam914   I have never had that tight of a car to worry abou...   Jul 5 2013, 07:17 AM
GeorgeRud   Webasto and Eberspacher are the two most common on...   Jul 5 2013, 07:24 AM
mepstein   heated seats   Jul 5 2013, 07:27 AM
Garold Shaffer   :bump: Just wanted to give this thread a bump si...   Oct 23 2013, 06:21 AM
JmuRiz   All I wish is that SSI (the new one) would make so...   Oct 23 2013, 07:49 AM
mepstein   All I wish is that SSI (the new one) would make s...   Oct 23 2013, 08:23 AM
mr914   There is ferrous and non-ferrous stainless. Best ...   Oct 24 2013, 02:12 AM
Garold Shaffer   :bump: Since the weather is starting to cool off...   Sep 24 2014, 10:07 AM
buck toenges   :bump: Since the weather is starting to cool of...   Sep 24 2014, 11:48 AM
KaptKaos   Just saw this, and it may explain the leak that I ...   Sep 24 2014, 10:41 AM
euro911   Just saw this, and it may explain the leak that I...   Sep 24 2014, 08:42 PM
GeorgeRud   If the exchangers are on the car, a simple battery...   Sep 24 2014, 12:23 PM
barefoot   I posted this last year, heating season is here a...   Sep 24 2014, 06:18 PM
RobW   Yikes! Forget heat then... :unsure:   Sep 24 2014, 09:51 PM
Phoenix914   Here is a link to another battery operated CO dete...   Sep 25 2014, 05:51 AM
Spoke   ???   Mar 5 2015, 01:02 PM
ThePaintedMan   That looks just like a set I bought off of Ebay......   Mar 5 2015, 01:26 PM
Garold Shaffer   Yep, had a perfect looking set of 2.0l exchangers ...   Mar 5 2015, 07:18 PM
nathansnathan   Whenever I bolt the heat exchangers to a motor, I ...   Sep 25 2015, 04:25 PM
Johny Blackstain   Anyone have a clue as to who made them for "A...   Sep 25 2015, 04:30 PM
Dave_Darling   I'm pretty sure that SSI made all of the 914 f...   Sep 25 2015, 06:19 PM
SirAndy   I'm pretty sure that SSI made all of the 914 f...   Sep 25 2015, 07:06 PM
dr914@autoatlanta.com   Right Dave, John Danials at Stainless Systems made...   Jan 30 2019, 09:27 AM
Johny Blackstain   I'm pretty sure that SSI made all of the 914 ...   Sep 25 2015, 07:15 PM
Katmanken   Don't think so. A metalurgist for GE aircraft ...   Sep 25 2015, 09:36 PM
bretth   So are you saying that if it is not magnetic it is...   Sep 26 2015, 06:36 AM
porschetub   I posted this last year, heating season is here a...   Sep 26 2015, 02:43 AM
RobW   Tangerine or headers.Not the end of the world.   Sep 26 2015, 06:07 AM
barefoot   I just checked my 1.7/1.8 SSI's and neither th...   Sep 26 2015, 07:01 AM
914ltd   Hey 'teeners, It's time to bring this up a...   Oct 1 2015, 07:15 AM
GaroldShaffer   Little late in bumping this thread. Never to late ...   Jan 29 2019, 10:58 PM
914ltd   Little late in bumping this thread. Never to late...   Jan 30 2019, 08:56 AM
mb911   This rule is for any and all heat exchangers.. Kee...   Jan 30 2019, 10:11 AM
Dave_Darling   We have just seen an SSI on the Facebook group tha...   Jan 30 2019, 11:44 AM
mb911   We have just seen an SSI on the Facebook group th...   Jan 30 2019, 12:13 PM
GeorgeRud   You can get a battery powered CO detector for ...   Jan 30 2019, 05:51 PM
worn   You can get a battery powered CO detector for ...   Jan 30 2019, 07:55 PM
euro911   You can get a battery powered CO detector for ...   Jan 31 2019, 02:36 AM
Mark Henry   You can get a battery powered CO detector for ...   Jan 31 2019, 08:01 AM
StratPlayer   Who is making SS exchangers?   Jan 30 2019, 08:01 PM
mb911   Who is making SS exchangers? For a 4cyl no idea...   Jan 30 2019, 08:37 PM
DRPHIL914   Who is making SS exchangers? For a 4cyl no ide...   Jan 31 2019, 07:07 AM
euro911   Those are cool ... I'll have to get a couple o...   Jan 31 2019, 12:25 PM
914ltd   I wanted to post this again. I was just reminded w...   Oct 15 2020, 12:20 PM
rbzymek   Thanks for the heads up. Just ordered a $20 ...   Oct 15 2020, 03:22 PM
horizontally-opposed   Yikes. This thread is a good reminder to find ot...   Oct 15 2020, 05:28 PM
mepstein   Yikes. This thread is a good reminder to find o...   Oct 16 2020, 06:18 AM
euro911   Yep. I have a pair of 914 Rubber's seat heater...   Oct 16 2020, 01:35 AM
mb911   Ask Michael about heat in his car or Steve or any ...   Oct 16 2020, 08:07 AM
horizontally-opposed   We are actually working on a simpler hopefully ch...   Oct 16 2020, 09:28 AM
horizontally-opposed   I don't at all disagree that heat exchangers a...   Oct 16 2020, 08:42 AM
914ltd   The header pipes can be filled with water to check...   Oct 16 2020, 09:32 AM
- Lo-Fi Version Time is now: 12th October 2026 - 03:13 PM
