> 914-4 vacuum hose locations
monkei
post Sep 11 2004, 12:34 PM
slave to rust....
hello, patrick a. here. just accquired a 1974 1.8l 914-4 and i have a good bit of work to do to make this vehicle in any sort of shape to go long distance cruisin/autocrossing. various electrical gremlins/nasty old rubber fuel lines and a lot of general tune up needs to be taken care of. im having trouble figuring out where some loose vacuum lines are to be routed. this first picture shows some vacuum valve that i believe is routed to that evap. can that looks like a tiny muffler and has a cut line that im not sure where to put:
monkei
post Sep 19 2004, 12:30 AM
slave to rust....
thanks for the pic and the link! i should be able to peice it together using that. im pretty sure its a d-jet. im positive its a 2.0 ga. anybody installed the solid motor mounts? is that a real tough installation? the drivetrain or car seems to buck when i shift. im gonna take care of some leaky fuel hoses around the fuel filter tomorrow. next things: buff the car out, solve brake light switch issue, and try to figure out the turn/e-flasher relay/wiring problem.
monkei   914-4 vacuum hose locations   Sep 11 2004, 12:34 PM
monkei   the next pic shows an open vacuum port (middle fro...   Sep 11 2004, 12:37 PM
monkei   btw that rediculous white thing is some plastic pl...   Sep 11 2004, 12:40 PM
monkei   looked through the complete shop manual set my dad...   Sep 11 2004, 12:42 PM
SpecialK   PP to the rescue....if you haven't already, bo...   Sep 11 2004, 12:47 PM
SirAndy   also, don't worry about that second vac-port o...   Sep 11 2004, 01:11 PM
monkei   im gonna print up the PP diagrams and see what i c...   Sep 11 2004, 01:57 PM
monkei   well, i feel kind of stupid. i was getting pretty ...   Sep 17 2004, 08:09 PM
2-OH!   If it really is a 2.0, then the port on the back o...   Sep 17 2004, 08:32 PM
mike_the_man   Here's a pic that might help you out.   Sep 17 2004, 09:46 PM
Jeff Bowlsby   By the boot in your photo, your wiring harness is ...   Sep 17 2004, 10:12 PM
SpecialK   Here ya go! http://www.pelicanparts.com/914/t...   Sep 17 2004, 10:17 PM
Bruce Allert   Anyone know why some 2.0 throttle bodies have just...   Sep 17 2004, 11:22 PM
monkei   thanks for the pic and the link! i should be a...   Sep 19 2004, 12:30 AM
monkei   both the picture and the PP diagram dont show a ch...   Sep 19 2004, 12:36 AM
SLITS   1. Take the smog crap off (but save it for a whil...   Sep 19 2004, 08:22 AM
monkei   fuel burns!!!!! next time i re...   Sep 19 2004, 02:07 PM
monkei   my 2.0 has the single vacuum port on the throttle ...   Sep 19 2004, 04:39 PM
2-OH!   Monkei: I have found the Pelican diagram to be......   Sep 20 2004, 07:56 AM
monkei   i totally empathize with it being hard to describe...   Sep 20 2004, 05:48 PM
- Lo-Fi Version Time is now: 10th December 2025 - 08:20 AM
