> Adjusting the valves, quick and short questions., NOW I need help on timing !!!! PLEASE
913B
post Sep 18 2015, 10:36 AM
I am checking the valves because they seem noisy and also to track down an erratic idle
I have read the rocking method but I would like to stick with the dizzy and TDC method please.
I read cyl #1 & #3 has same TDC and #2 & #4 has same TDC
Question 1 – Setting TDC on the fan notch does it have to be at “0” or will the notch for “27BTDC” work too
When I find TDC for #1 on fan notch and dizzy rotor is pointing to #1 tower of dizzy cap
Question 2 - Can I adjust all the valves for #1 and #3 cyl ??
Then rotating the motor to #2 TDC on fan notch and dizzy is pointing to #2 tower
Question 3. Can I adjust all the valves for #2 and #4 cyl ??
Question 4. Is it wise to replace the cork valve cover and not risk a leak.
The gasket is pretty new though and low mileage since I last had them off.
I am thinking of purchasing the 914rubber re-usable ones. Any recommendation’s
Thanks everyone !
Ted
913B
post Sep 26 2015, 04:49 PM
Yes timing light clamp on #1 plug wire
porsche913b_sp   Adjusting the valves, quick and short questions.   Sep 18 2015, 10:36 AM
dangrouche   http://www.914world.com/bbs2/index.php?showtopic=2...   Sep 18 2015, 11:07 AM
stugray   If you have never done it before, I suggest you do...   Sep 18 2015, 04:32 PM
r_towle   The camshaft shares the same lobe for the two valv...   Sep 18 2015, 05:33 PM
Dave_Darling   I use the "book" method, which means set...   Sep 18 2015, 06:29 PM
stugray   I agree that "the crusty method" is the ...   Sep 18 2015, 10:49 PM
porsche913b_sp   Can someone please confirm I am doing this right. ...   Sep 19 2015, 01:08 PM
era vulgaris   Another odd thing the valve cover on drivers sid...   Sep 20 2015, 07:10 AM
The Cabinetmaker   You have to make a mark on the flywheel. While und...   Sep 19 2015, 02:26 PM
stugray   Did you check the video link I posted above? For ...   Sep 19 2015, 03:13 PM
Steve Pratel   Good Lord this is giving me agita........... I...   Sep 19 2015, 03:39 PM
The Cabinetmaker   Hey Steve, I think you mean angina. Lol. Don't...   Sep 19 2015, 04:59 PM
Steve Pratel   Hey Steve, I think you mean angina. Lol. Don...   Sep 19 2015, 10:14 PM
porsche913b_sp   Thanks for all the help everyone. I lined up the ...   Sep 19 2015, 10:38 PM
stugray   How do I time it using the notch on the top, do ...   Sep 19 2015, 11:00 PM
porsche913b_sp   So why is it that the marks on the fan is off and ...   Sep 19 2015, 11:53 PM
Dave_Darling   So why is it that the marks on the fan is off and...   Sep 20 2015, 04:42 PM
The Cabinetmaker   I've read the upside down thing so many times....   Sep 20 2015, 12:59 PM
theleschyouknow   thought read somewhere about the type -4s being or...   Sep 20 2015, 01:29 PM
The Cabinetmaker   Buses have engine tin too.   Sep 20 2015, 01:31 PM
The Cabinetmaker   How's the red dog, cj? What breed is she? I fo...   Sep 20 2015, 01:33 PM
theleschyouknow   ahh.... the tin ah so maybe initially installed by...   Sep 20 2015, 02:16 PM
The Cabinetmaker   He's not crazy, just very alert.   Sep 20 2015, 03:48 PM
The Cabinetmaker   Damn it. I did it again.   Sep 20 2015, 03:58 PM
theleschyouknow   :beer2: I had a pic of him in that reply but it w...   Sep 20 2015, 04:07 PM
era vulgaris   Cap'n Krusty always said that the tab that sti...   Sep 20 2015, 04:29 PM
hedfurst   1. All 4 cylinder ACVW motors have the same basic ...   Sep 20 2015, 04:51 PM
porsche913b_sp   Ok the valve adjustment is done now trying to time...   Sep 26 2015, 02:33 PM
porsche913b_sp   Update: I can sort of get idle to come to 900 but ...   Sep 26 2015, 03:06 PM
The Cabinetmaker   Timing light clamp on #1? That's drivers side ...   Sep 26 2015, 03:57 PM
porsche913b_sp   Yes timing light clamp on #1 plug wire   Sep 26 2015, 04:49 PM
stugray   check to make sure the advance mechanism in the di...   Sep 27 2015, 10:20 AM
porsche913b_sp   I checked advance and retard with mity vac and the...   Sep 27 2015, 11:15 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:03 PM
