> Getting rid of the gas smell
post Feb 28 2015, 10:40 AM
914-6 GT in waiting
In the past I:
Ran new fuel and vacume lines
Cleaned the interior
Replaced seals and gaskets on the fuel injection
Today I decided it was time to replace the charcoal in the canister next to the fuel tank
I purchased some replacement charcoal on Amazon. I've read that this isn't optimal but I feel it's got to be better than leaving the 45 year old origional mixture in the car.
bperry
post Sep 27 2015, 02:05 PM
Lurker
I'll be curious how well it works. The main thing that concerns me is the "charcoal" itself.
What does the original carbon in the filter look like?
I've been actively maintaining aquariums for a hobby for over 40 years and never had good look with the pellitized charcoal. It was much cheaper but at least for use in aquarium filters, to put it bluntly, "it sucked". It didn't maintain the water quality even close to the way activated carbon granules does.
The best stuff I've used is Marineland Black Diamond activated carbon.
Another one I've recently started using is Premium granulated carbon under the Doctors Foster and Smith brand from their website. A bit lower cost than the Black Diamond but seems to work as well.
At least with the carbon for aquariums you can tell the good stuff as soon as you rinse it.
You can hear the carbon sizzling as it makes contact with the water.
The worst stuff I ever used was from Hartz.
That stuff looked like actual coal (shiny and very hard) and had no filtering capability at all.
--- bill
mepstein   Getting rid of the gas smell   Feb 28 2015, 10:40 AM
mepstein   Unlike the mid and late model 914's, on the ea...   Feb 28 2015, 10:43 AM
mepstein   Originally I drilled a small hole but when I dumpe...   Feb 28 2015, 11:01 AM
porsche913b_sp   Keep us updated if it gets rid of the gas smell. I...   Feb 28 2015, 11:27 AM
mepstein   The new lines, clamps and seals made a big differe...   Feb 28 2015, 11:35 AM
mepstein   Next time I'll use a hole saw with the same di...   Feb 28 2015, 12:42 PM
Larmo63   Maybe, (probably) a dumb question here, but do tho...   Feb 28 2015, 01:36 PM
r_towle   It takes away the smell in the trunk which flows i...   Feb 28 2015, 02:37 PM
quadracerx   It takes away the smell in the trunk which flows ...   Sep 27 2015, 01:00 PM
patssle   What about gas/moisture getting into the canister ...   Feb 28 2015, 03:56 PM
bperry   I'll be curious how well it works. The main th...   Sep 27 2015, 02:05 PM
boxsterfan   Did you change the rubber gasket on the fuel fille...   Sep 27 2015, 05:10 PM
Dominic   Did you change the rubber gasket on the fuel fill...   Sep 28 2015, 10:26 PM
Vysoc   Question for bperry? Is there enough room in the ...   Sep 27 2015, 05:53 PM
bperry   Question for bperry? Is there enough room in the...   Sep 28 2015, 10:21 PM
mepstein   Guys, make sure you have replaced all 3 seals on t...   Sep 27 2015, 05:56 PM
arsprod   Guys, make sure you have replaced all 3 seals on ...   Oct 9 2015, 09:16 PM
mepstein   Guys, make sure you have replaced all 3 seals on...   Oct 10 2015, 06:10 AM
RobW   [quote name='arsprod' post='2249994' date='Oct 9 ...   Oct 10 2015, 06:18 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:12 PM
