| mepstein |
Feb 28 2015, 10:40 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
In the past I:
Ran new fuel and vacume lines Cleaned the interior Replaced seals and gaskets on the fuel injection Today I decided it was time to replace the charcoal in the canister next to the fuel tank I purchased some replacement charcoal on Amazon. I've read that this isn't optimal but I feel it's got to be better than leaving the 45 year old origional mixture in the car. Attached thumbnail(s) |
| boxsterfan |
Sep 27 2015, 05:10 PM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Did you change the rubber gasket on the fuel filler going into the tank? I replaced all the hoses and gaskets in mine but the smell was still there. Replaced the gasket under the fuel filler neck and presto!!
| Dominic |
Sep 28 2015, 10:26 PM
Dominic ![]() ![]() ![]() Group: Members Posts: 995 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Did you change the rubber gasket on the fuel filler going into the tank? I replaced all the hoses and gaskets in mine but the smell was still there. Replaced the gasket under the fuel filler neck and presto!! (IMG:style_emoticons/default/agree.gif) This fixed my gas smell as well...cheap fix, get a new seal from 914rubber.com |
mepstein Getting rid of the gas smell Feb 28 2015, 10:40 AM
mepstein Unlike the mid and late model 914's, on the ea... Feb 28 2015, 10:43 AM
mepstein Originally I drilled a small hole but when I dumpe... Feb 28 2015, 11:01 AM
porsche913b_sp Keep us updated if it gets rid of the gas smell. I... Feb 28 2015, 11:27 AM
mepstein The new lines, clamps and seals made a big differe... Feb 28 2015, 11:35 AM
mepstein Next time I'll use a hole saw with the same di... Feb 28 2015, 12:42 PM
Larmo63 Maybe, (probably) a dumb question here, but do tho... Feb 28 2015, 01:36 PM
r_towle It takes away the smell in the trunk which flows i... Feb 28 2015, 02:37 PM
quadracerx
It takes away the smell in the trunk which flows ... Sep 27 2015, 01:00 PM
patssle What about gas/moisture getting into the canister ... Feb 28 2015, 03:56 PM
bperry I'll be curious how well it works. The main th... Sep 27 2015, 02:05 PM
Vysoc Question for bperry?
Is there enough room in the ... Sep 27 2015, 05:53 PM
bperry
Is there enough room in the... Sep 28 2015, 10:21 PM
mepstein Guys, make sure you have replaced all 3 seals on t... Sep 27 2015, 05:56 PM
arsprod
Guys, make sure you have replaced all 3 seals on ... Oct 9 2015, 09:16 PM
Guys, make sure you have replaced all 3 seals on... Oct 10 2015, 06:10 AM
RobW
[quote name='arsprod' post='2249994' date='Oct 9 ... Oct 10 2015, 06:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:42 PM |
