| monkei |
Sep 11 2004, 12:34 PM
slave to rust.... ![]() ![]() Group: Members Posts: 137 Joined: 10-August 04 From: Pleasanton, CA Member No.: 2,504 |
hello, patrick a. here. just accquired a 1974 1.8l 914-4 and i have a good bit of work to do to make this vehicle in any sort of shape to go long distance cruisin/autocrossing. various electrical gremlins/nasty old rubber fuel lines and a lot of general tune up needs to be taken care of. im having trouble figuring out where some loose vacuum lines are to be routed. this first picture shows some vacuum valve that i believe is routed to that evap. can that looks like a tiny muffler and has a cut line that im not sure where to put:
| monkei |
Sep 19 2004, 04:39 PM
my 2.0 has the single vacuum port on the throttle body for the dist (diagram shows two pic shows one), the diagrams and pictures im looking at dont tell me about the charcoal canisters 3 ports and how theyre supposed to be routed , or where the vac line from the expansion tank ( i think) coming up from under the car through the engine tin goes. im having a bit of trouble trying to sort it out. i try to switch a line from one location to another as seen on a diagram and the diameters of the hose and port dont match and the like.... itd be nice to look at another 74 djet 2.0 to compare. my decel valve isnt even mounted along with some other large thing with 1 vacuum line going nowhere and an electrical connector. she started and idled nicely today when i first started after replacing a leaky 3-4" section of old fuel hose under the car that connects the fuel inlet to the filter. i still want to replace three other short sections of old hose down near the fuel pump and filter, all the hose come off of this plastic tri-junction. the idle wasnt as nice after i washed the car but i think that was just because the motor was warm from my little cruise. (btw, my car, when running, still creates a huge vacuum when the gas cap is on) i noticed a pool of standing water 2-3 inches deep at the most in the engine bay in the front corner on the drivers side. what is a good way to create a drain so it doesnt sit and rust? as mentioned in the earlier short post, i got all these weird burns on my neck and arms from the gas, i need to take a shower. i think im done for today. got the motor and tranny mounts confused... will solid tranny mounts (in rear) put any huge stress on the transaxle? would the 911 sport mounts be a good replacement for the front? whats involved in replacing both. do you just undo mounts and jack the drivetrain up enough to remove the old mounts and get new ones in? that seems to easy for a 914. clearance issues? other things need to be disconnected/removed to pull it of im sure...
btw wheres this 914 breakfast going down? my dads hosted a 914 gathering at his business before, and i autocrossed his car at marina so ive met some folks already. he did the west coast classic trip, or part of it. hes currently got his car at high performance house in redwood city getting a bunch of things done. (1.7l swapped out for a 2056cc, shift kit, new mounts etc..) |
monkei 914-4 vacuum hose locations Sep 11 2004, 12:34 PM
monkei the next pic shows an open vacuum port (middle fro... Sep 11 2004, 12:37 PM
monkei btw that rediculous white thing is some plastic pl... Sep 11 2004, 12:40 PM
monkei looked through the complete shop manual set my dad... Sep 11 2004, 12:42 PM
SpecialK PP to the rescue....if you haven't already, bo... Sep 11 2004, 12:47 PM
SirAndy also, don't worry about that second vac-port o... Sep 11 2004, 01:11 PM
monkei im gonna print up the PP diagrams and see what i c... Sep 11 2004, 01:57 PM
monkei well, i feel kind of stupid. i was getting pretty ... Sep 17 2004, 08:09 PM
2-OH! If it really is a 2.0, then the port on the back o... Sep 17 2004, 08:32 PM
mike_the_man Here's a pic that might help you out. Sep 17 2004, 09:46 PM
Jeff Bowlsby By the boot in your photo, your wiring harness is ... Sep 17 2004, 10:12 PM
SpecialK Here ya go!
http://www.pelicanparts.com/914/t... Sep 17 2004, 10:17 PM
Bruce Allert Anyone know why some 2.0 throttle bodies have just... Sep 17 2004, 11:22 PM
monkei thanks for the pic and the link! i should be a... Sep 19 2004, 12:30 AM
monkei both the picture and the PP diagram dont show a ch... Sep 19 2004, 12:36 AM
SLITS 1. Take the smog crap off (but save it for a whil... Sep 19 2004, 08:22 AM
monkei fuel burns!!!!! next time i re... Sep 19 2004, 02:07 PM
2-OH! Monkei:
I have found the Pelican diagram to be...... Sep 20 2004, 07:56 AM
monkei i totally empathize with it being hard to describe... Sep 20 2004, 05:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 08:22 AM |
