> jim kelly's 1975 914 suby build, water pump housing and header interference ???
jimkelly
post Sep 26 2015, 10:40 AM
Delaware USA
i have a 1975 914 roller and a a few ej22 engines and a couple of suby 5 spd transaxles
https://www.diyautotune.com/shop/megasquirt...ed/microsquirt/
microsquirt with 8" harness $370
GM clt sensor 3/8 npt $17
GM iat sensor 3/8 npt $22
GM map sensor $75
3/8 npt tap $10
18x1.5 tap $12
18x1.5 bung for aem o2 sensor $4
AEM 30-4110 $165
Set of 6 Pcs Spark Plug Ignition Wire Lead For 2.8L VW Passat $30
VW bug Beetle golf oem 2.0 ignition coil pack assembly 032905106b $20
Subaru WRX OEM Crankshaft Timing Sprocket pn-13021AA141 $30
celica radiator 2 row - $170 (see post #2 and my v8 thread)
exhaust header - $35 ebay (see post #152) (decided to go with wrx oem stock header for compactness)
stainless fuel lines - $99 tangerine - 8mm supply and 8mm return
stopper drive pinion - made myself
http://www.914world.com/bbs2/index.php?showtopic=104513
stock 914 axles machined on one end - $150 Dutchman
tires - 185x50x15 - $300+-[/b]
engine cradle and trans hangars - mepstein $550 (see post #32)
mr2 shifter - $35 ebay
shift knob ebay $12 (see post #170)
front bumper grills - $35 dflesburg
stock style fuses - ebay $13
set of speed bleeders - $30 pelican
brake peddle switch - $24 pelican
ebrake handle assy with cable and equalizer - $56 bdstone914
lug bolts to roll car around my garage - free mark epstein
set of nice complete late model doors - $150 (thanks lorin, series9, rat rod charlie)
center section of fuse box - free mark epstein
a front steel bumper - free mark epstein
late model tach with single directional indicator - cabinetmaker $40 shipped : )
two pair front amber lens bought from 914rubber for both my cars.
https://weddleindustries.com/products/1000186/1001853 - flange $50 shipped type 1 to type 2/4
starter 23300AA560 - http://www.914world.com/bbs2/index.php?showtopic=303903
looking forward to...
good fuel mileage
modern fuel injection
modern 5spd transaxle - useable 1st gear for taking off from dead stop & in traffic
light weight car
big space in engine bay
running some low profile 15 inch tires on 5.5" wheels - maybe 185x50x15
reference materials and links...
http://www.shoptalkforums.com/viewtopic.php?t=136053
http://www.surrealmirage.com/subaru/swap/electrical.html
http://legacycentral.org/
http://www.northursalia.com/modifications/...lschematics.pdf
http://www.main.experiencetherave.com/subaru_manual_scans/
vanagon related links...
http://subaruvanagon.com/conversion_services_Wiring.htm
https://smallcar.com/vanagon/subaru-vanagon...cation-kit.html
http://www.kennedyenginc.com/Pages/SubaruVanagonGen.aspx
http://www.rockymountainwesty.com/v/vspfil...nstructions.pdf
http://www.weidefamily.net/vanagon/HTML/05/main.html
http://www.ultimatesubaru.org/forum/topic/...iring-diagrams/
http://www.numbchuxconversions.com/Files/Harness%20info.pdf
http://consumerguide.com/used/1990-94-subaru-legacy/
pulling ej22 harness from subaru (Tim Seward) per tim 90 and 91 harnesses are same
https://www.youtube.com/watch?v=GfQJnZBljsw
be sure to watch all (busaru) segments
https://www.youtube.com/watch?v=ENm6S3WkKJc
Subaru engine test stand (Jeff Robenolt)
https://www.youtube.com/watch?v=_IN5rfK9a_8
jimkelly
post Sep 30 2015, 06:53 PM
Delaware USA
i'll try to blend ACQUISITION with ACTUAL BUILD photos and text.
my car needs some welding, but the rest will mostly be bolt in. nothing too fancy, that is for sure. super low dollar build. planning on frankenstein axles or have dutchman machine some.
http://www.dutchmanaxles.com/
mgp4591
post Oct 1 2015, 09:06 PM
QUOTE(jimkelly @ Sep 30 2015, 06:53 PM) *
Do you know of anyone here or elsewhere using these axles or any idea of the cost?
jimkelly   jim kelly's 1975 914 suby build   Sep 26 2015, 10:40 AM
jimkelly   this ebay radiator was mentioned by a member. the...   Sep 29 2015, 02:30 PM
jimkelly   some sensor fake output info... from tonyakavw an...   Sep 29 2015, 02:32 PM
r_towle   Wait, what? Don't you have a v8?   Sep 29 2015, 04:04 PM
Smallblockbug   Im pretty sure this is his other car. But yes he h...   Sep 29 2015, 04:31 PM
jimkelly   i have a wife, 2 boys, and two 914s. that is about...   Sep 29 2015, 06:31 PM
Stacks914   I am sorry did you mention fuel mileage??? LOL jk...   Sep 30 2015, 01:48 AM
jimkelly   YES, yes i did. it will be my daily driver once c...   Sep 30 2015, 07:01 AM
mepstein   YES, yes i did. it will be my daily driver once ...   Sep 30 2015, 07:09 AM
76-914   When does the build start? Not a fan of acquisitio...   Sep 30 2015, 09:21 AM
mepstein   When does the build start? Not a fan of acquisiti...   Sep 30 2015, 09:39 AM
76-914   When does the build start? Not a fan of acquisit...   Sep 30 2015, 04:00 PM
mepstein   [quote name='mepstein' post='2245415' date='Sep 3...   Sep 30 2015, 05:52 PM
jimkelly   i'll try to blend ACQUISITION with ACTUAL BUIL...   Sep 30 2015, 06:53 PM
mgp4591   i'll try to blend ACQUISITION with ACTUAL BUI...   Oct 1 2015, 09:06 PM
jimkelly   $35 ebay actual unit as received   Oct 1 2015, 06:33 PM
A&P Mech   All those pieces and parts look familiar. :) What...   Oct 1 2015, 06:50 PM
jimkelly   Dutchman has been recommended by bigkat_83 who is ...   Oct 2 2015, 08:52 AM
76-914   Dutchman has been recommended by bigkat_83 who is...   Oct 2 2015, 09:47 AM
mgp4591   Sweet idea for the axles- I may just send my SVX a...   Oct 2 2015, 10:38 PM
jimkelly   sawtooths axles >> has anyone used this dim...   Oct 3 2015, 06:12 AM
76-914   sawtooths axles >> has anyone used this di...   Oct 3 2015, 08:20 AM
jimkelly   your conversion was epic - others can see it here....   Oct 3 2015, 10:24 AM
jimkelly   why I MUST HAVE a Subaru engine and trans :D AL...   Oct 3 2015, 06:15 AM
Chris H.   why I MUST HAVE a Subaru engine and trans :D ...   Oct 3 2015, 01:34 PM
Justinp71   why I MUST HAVE a Subaru engine and trans :D ...   Apr 1 2016, 05:37 PM
jimkelly   OD of splined end of stock 914 axle is 1.066. wha...   Oct 7 2015, 12:56 PM
76-914   OD of splined end of stock 914 axle is 1.066. wh...   Oct 12 2015, 08:20 PM
mepstein   Jim - if you or someone will tell me how to remove...   Oct 7 2015, 03:59 PM
mgp4591   Jim - if you or someone will tell me how to remov...   Oct 7 2015, 04:53 PM
jimkelly   once upon a time, i had a legacy parts car and rem...   Oct 7 2015, 04:03 PM
jimkelly   Ms_UZ43u4CQ   Oct 7 2015, 05:10 PM
mepstein   Thanks guys. I'll probably cheat and have on...   Oct 7 2015, 06:08 PM
jimkelly   decided to drive the pickup truck to mark's sh...   Oct 9 2015, 11:34 AM
jimkelly   finally got my 1975 back onto some wheels and tire...   Oct 10 2015, 04:10 PM
jimkelly   how could i best protect these pin holed longs wit...   Oct 12 2015, 11:07 AM
Andyrew   how could i best protect these pin holed longs wi...   Oct 15 2015, 04:15 PM
jimkelly   my buddy - rat rod charlie - is on his way to dayt...   Oct 12 2015, 03:38 PM
jimkelly   got me some doors coming via series9's shop.   Oct 15 2015, 02:51 PM
jimkelly   my head light question thread at this link... pics...   Oct 16 2015, 12:00 PM
jimkelly   decided that I will just put a delrin spacer here ...   Oct 18 2015, 05:54 AM
jimkelly   new doors coming home today. guess i'll put w...   Oct 30 2015, 02:56 PM
flmont   Jim,..how do U intend to run the water lines under...   Oct 30 2015, 10:12 PM
jimkelly   under - it is tried and true - but thru longs give...   Oct 30 2015, 10:36 PM
rightpedal   Jim I laugh every time I see the "pickup...   Oct 31 2015, 05:16 AM
jimkelly   white doors are back on my 1975 and red doors are ...   Oct 31 2015, 04:37 PM
914forme   And to think I just man handle doors in place, put...   Oct 31 2015, 05:09 PM
jimkelly   thank god I had the hoist... no way could I have i...   Oct 31 2015, 06:50 PM
jimkelly   yesterday I picked up a fuse box section and a fro...   Nov 1 2015, 08:03 AM
mepstein   Save your old fuse panel in case you or someone el...   Nov 1 2015, 09:07 AM
jimkelly   mark - that is awesome - I am so glad I got a kid ...   Nov 1 2015, 09:23 AM
mepstein   mark - that is awesome - I am so glad I got a kid...   Nov 1 2015, 09:33 AM
jimkelly   just stripped down the bumper. i'll be return...   Nov 1 2015, 10:26 AM
jimkelly   well, I still don't understand how you guys ac...   Nov 7 2015, 08:27 AM
Andyrew   well, I still don't understand how you guys a...   Nov 7 2015, 11:18 AM
mepstein   Pm me your address and I'll send down some cli...   Nov 7 2015, 08:49 AM
jimkelly   mark, how about I visit next week, I need to bring...   Nov 7 2015, 08:58 AM
mepstein   mark, how about I visit next week, I need to brin...   Nov 7 2015, 09:09 AM
jimkelly   guess if I just remove lens, maybe I would have a ...   Nov 7 2015, 11:46 AM
914forme   Small bit and bit holder does the trick also, remo...   Nov 7 2015, 02:03 PM
jimkelly   (( driver bit in fingers seems like a decent solut...   Nov 7 2015, 02:19 PM
jimkelly   since i have been getting my lights and guages rei...   Nov 9 2015, 04:37 PM
jimkelly   it turns out that my car has dash wiring for EGR a...   Nov 11 2015, 10:22 AM
jimkelly   tested my buddy's theory that my battery charg...   Nov 14 2015, 09:45 AM
jimkelly   did a loose bolt/wire check and found 3 nuts at bo...   Nov 15 2015, 05:39 PM
jimkelly   got me some stuff from 914rubber :)   Nov 25 2015, 09:41 PM
jimkelly   did a little something on my 75 today. got some s...   Nov 29 2015, 12:27 PM
jimkelly   think i found my parts car, a lowly ej22 in need o...   Mar 31 2016, 02:18 PM
matthepcat   ^^That motor has a factory forged crank ^^ You ca...   Mar 31 2016, 02:47 PM
jimkelly   one step closer... with a 1990 subaru legacy awd.....   Mar 31 2016, 08:26 PM
76-914   one step closer... BUT NOT TO TURBO :D time to...   Apr 1 2016, 08:41 AM
jimkelly   i'm concerned. i knew the engine has some iss...   Apr 1 2016, 01:10 PM
zipedadoo   What year is the subaru? I used a 1996 ej22. I fou...   Apr 1 2016, 01:54 PM
jimkelly   1990 subaru legacy awd.. must have been sitting fo...   Apr 1 2016, 02:29 PM
Chris H.   No the car in that clip is a 4 cylinder turbo car....   Apr 1 2016, 10:21 PM
jimkelly   all he said was that he stopped running it cause h...   Apr 2 2016, 05:57 AM
jimkelly   ok, engine runs but weak. seems spark is ok but n...   Apr 6 2016, 06:45 AM
jimkelly   got me second ej22 today $100.   Apr 6 2016, 06:02 PM
Andyrew   got me second ej22 today $100. You and you...   Apr 12 2016, 03:34 PM
jimkelly   my 1990 subaru legacy 5spd awd, pulling harness, t...   Apr 12 2016, 03:06 PM
jimkelly   thank you andy :D at a gas station on the way b...   Apr 12 2016, 04:11 PM
jimkelly   great thread on repairing shielded suby wires. htt...   May 29 2016, 10:27 AM
jimkelly   pulled engine and trans last night. made a cradle ...   Jun 10 2016, 06:07 PM
76-914   The Fun begins Jim. :popcorn: You may need a few ...   Jun 10 2016, 06:24 PM
jimkelly   I have several wires to fix on my harness. someho...   Jun 11 2016, 03:19 PM
mepstein   I have several wires to fix on my harness. someh...   Jun 11 2016, 03:43 PM
arkitect   got me second ej22 today $100. Cool use of...   Jun 10 2016, 10:37 PM
jimkelly   thanks :) got me second ej22 today $100....   Jun 11 2016, 03:16 PM
jimkelly   ambitious, no. :poke: poking myself :D frugal...   Jun 11 2016, 04:35 PM
76-914   ambitious, no. :poke: poking myself :D fruga...   Jun 12 2016, 03:24 PM
mepstein   ambitious, no. :poke: poking myself :D frug...   Jun 12 2016, 05:46 PM
rightpedal   I might be able to help with the cradle. Want to ...   Jun 12 2016, 07:00 PM
jimkelly   I already have the suby cradle and trans hangers f...   Jun 12 2016, 07:21 PM
jimkelly   i bit off topic but i am making my recently bought...   Jun 27 2016, 05:58 AM
jimkelly   engine stand getting closer to finished and closer...   Jul 1 2016, 09:10 PM
jimkelly   latest of engine on stand... amnd video of harness...   Jul 13 2016, 04:51 PM
jimkelly   decided to try a microsquirt based on many youtube...   Apr 5 2017, 06:15 AM
76-914   Good to see you haven't given up. MS is easier...   Apr 5 2017, 07:59 AM
jimkelly   guess i'll cross that bridge if i ever get the...   Apr 5 2017, 10:46 AM
jpnovak   MS2 ECU board fits nicely inside a stock Suby ECU ...   Apr 5 2017, 02:48 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 25th September 2026 - 12:01 PM
