My tire options and fitment. |
patssle |
Oct 4 2015, 01:38 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I'm currently running 185/65-15 cheapo tires. I want to upgrade to some performance tires (g-Force Sport COMP-2) and the only size I can get is 195/55-15. My passenger rear tire has the closest gap between the tire and fender being about 1/2" calculating for the widest part of the tire. None of the gaps on the other tires are the same and all are bigger. Also my rear tires have a rather significant negative camber as my inside threads are significantly more worn than the outside.
Should I be concerned about changing tire size at all and especially if I get an alignment which may reduce the camber (so the top part of the tire would be moved outwards)? |
patssle |
Oct 4 2015, 07:17 PM
I'm running the Mahle 4 lug wheels.
The space on the drivers rear is about 3/4" between the widest part of the tire and fender. So this one tire is really the only concerned spot. There just aren't that many performance tire options. The Yokohama s.drive is in 185/55 but that reduces the diameter by 6% 24.5 to 23. My car is already lowered so I'd probably need to raise it back up a little. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:34 PM |
