Oil Cooler for 2366? |
VWTortuga336 |
Oct 4 2015, 07:49 PM
Member Group: Members Posts: 285 Joined: 5-October 14 From: Kansas City, Missouri Member No.: 17,979 Region Association: None |
What would be my best solution for adding an oil cooler on the 2366 build I am starting? I've read about coolers that mount under the rear of the car and are cooled with a fan. Is this the right direction?
Dion |
Oct 5 2015, 09:16 AM
RN Group: Members Posts: 2,766 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
I have hi-comp 96mm P&C "2056".
914Dave & I came up with this setup to keep my oil temps healthy. Originally just a Mocal cooler sitting next to trans. When I upgraded to the "2056" we added the electric fan and shroud/box. Never really above 220F on a hot run, on a 90F day. Stays between 180-210F per the vdo gauge. This works for my set up. Not knowing your set. I imagine the heat units will be greater. Maybe trombone or other 911 style setup toward front for more volume of cooling air. Good luck. Cheers, Dion Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th June 2024 - 03:46 AM |
