Troubleshooting an AFR gauge/sensor, l**Finally Figured out my issue** |
jim_hoyland |
Oct 6 2015, 03:17 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I installed the Innovate MTX L in 2012 and it worked fine until June of the year when it would go into the E8 mode. The techs say this means a faulty sensor. I replaced it and have continued to have erratic activity.
For example: it may run in an acceptable range for a while, then suddenly go to reading either too high or too low that are unreasonable; it sometimes freezes on a reading, and at other times it goes to E8.If I turn the ignition off and restart the engine, the gauge goes to a normal reading, then goes through the same routine. This sensor is 3 months old, car is in perfect tune. I changed the 12v power source, used a different ground, and recalibrated several times Anyone had experience troubleshooting these AFR's ? UPDATE_It was caused by contamination ! I have been adding MMO to my my fuel over the past year. When I ran out of MMO, I just ran straightgas without MMO. The AFR sensor reverted to normal operation and all is good. Interesting...you'd think the MMO would burn off or dissipate by the time it reached the exaust. Now I;m wondering if the MMO caused exhaust smoke upon downhill deceleration ? |
Dtjaden |
Oct 6 2015, 08:59 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I installed mine about 1 1/2 years ago and have not seen this error. You have probably done these things but I would check and clean all connections and also try reloading the device firmware.
Innovate states the following is the MTX-L manual for an E8: 1. Perform sensor calibration. 2. Move sensor bung as far downstream as possible. 3. Add an HBX-1 (p/n 3729) to isolate the sensor from the pipe. 4. Replace sensor. Good luck! Darryl |
Lo-Fi Version | Time is now: 9th June 2024 - 06:42 AM |
