| jimkelly |
Sep 26 2015, 10:40 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i have a 1975 914 roller and a a few ej22 engines and a couple of suby 5 spd transaxles
https://www.diyautotune.com/shop/megasquirt...ed/microsquirt/ microsquirt with 8" harness $370 GM clt sensor 3/8 npt $17 GM iat sensor 3/8 npt $22 GM map sensor $75 3/8 npt tap $10 18x1.5 tap $12 18x1.5 bung for aem o2 sensor $4 AEM 30-4110 $165 Set of 6 Pcs Spark Plug Ignition Wire Lead For 2.8L VW Passat $30 VW bug Beetle golf oem 2.0 ignition coil pack assembly 032905106b $20 Subaru WRX OEM Crankshaft Timing Sprocket pn-13021AA141 $30 celica radiator 2 row - $170 (see post #2 and my v8 thread) exhaust header - $35 ebay (see post #152) (decided to go with wrx oem stock header for compactness) stainless fuel lines - $99 tangerine - 8mm supply and 8mm return stopper drive pinion - made myself http://www.914world.com/bbs2/index.php?showtopic=104513 stock 914 axles machined on one end - $150 Dutchman tires - 185x50x15 - $300+-[/b] engine cradle and trans hangars - mepstein $550 (see post #32) mr2 shifter - $35 ebay shift knob ebay $12 (see post #170) front bumper grills - $35 dflesburg stock style fuses - ebay $13 set of speed bleeders - $30 pelican brake peddle switch - $24 pelican ebrake handle assy with cable and equalizer - $56 bdstone914 lug bolts to roll car around my garage - free mark epstein set of nice complete late model doors - $150 (thanks lorin, series9, rat rod charlie) center section of fuse box - free mark epstein a front steel bumper - free mark epstein late model tach with single directional indicator - cabinetmaker $40 shipped : ) two pair front amber lens bought from 914rubber for both my cars. https://weddleindustries.com/products/1000186/1001853 - flange $50 shipped type 1 to type 2/4 starter 23300AA560 - http://www.914world.com/bbs2/index.php?showtopic=303903 /////////////////////////////////////////////////////////////////////////////////////////// looking forward to... good fuel mileage modern fuel injection modern 5spd transaxle - useable 1st gear for taking off from dead stop & in traffic light weight car big space in engine bay running some low profile 15 inch tires on 5.5" wheels - maybe 185x50x15 ////////////////////////////////////////////////////////////////////////////////////////// reference materials and links... http://www.shoptalkforums.com/viewtopic.php?t=136053 http://www.surrealmirage.com/subaru/swap/electrical.html http://legacycentral.org/ http://www.northursalia.com/modifications/...lschematics.pdf http://www.main.experiencetherave.com/subaru_manual_scans/ vanagon related links... http://subaruvanagon.com/conversion_services_Wiring.htm https://smallcar.com/vanagon/subaru-vanagon...cation-kit.html http://www.kennedyenginc.com/Pages/SubaruVanagonGen.aspx http://www.rockymountainwesty.com/v/vspfil...nstructions.pdf http://www.weidefamily.net/vanagon/HTML/05/main.html http://www.ultimatesubaru.org/forum/topic/...iring-diagrams/ http://www.numbchuxconversions.com/Files/Harness%20info.pdf http://consumerguide.com/used/1990-94-subaru-legacy/ pulling ej22 harness from subaru (Tim Seward) per tim 90 and 91 harnesses are same https://www.youtube.com/watch?v=GfQJnZBljsw be sure to watch all (busaru) segments https://www.youtube.com/watch?v=ENm6S3WkKJc Subaru engine test stand (Jeff Robenolt) https://www.youtube.com/watch?v=_IN5rfK9a_8 |
| mepstein |
Oct 7 2015, 03:59 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Jim - if you or someone will tell me how to remove the Suby axles from cv's, you can have my axles for free.
jimkelly jim kelly's 1975 914 suby build Sep 26 2015, 10:40 AM
jimkelly this ebay radiator was mentioned by a member. the... Sep 29 2015, 02:30 PM
jimkelly some sensor fake output info... from tonyakavw an... Sep 29 2015, 02:32 PM
r_towle Wait, what?
Don't you have a v8? Sep 29 2015, 04:04 PM
Smallblockbug Im pretty sure this is his other car. But yes he h... Sep 29 2015, 04:31 PM
jimkelly i have a wife, 2 boys, and two 914s. that is about... Sep 29 2015, 06:31 PM
Stacks914 I am sorry did you mention fuel mileage??? LOL jk... Sep 30 2015, 01:48 AM
jimkelly YES, yes i did. it will be my daily driver once c... Sep 30 2015, 07:01 AM
YES, yes i did. it will be my daily driver once ... Sep 30 2015, 07:09 AM
76-914 When does the build start? Not a fan of acquisitio... Sep 30 2015, 09:21 AM
When does the build start? Not a fan of acquisiti... Sep 30 2015, 09:39 AM
76-914
When does the build start? Not a fan of acquisit... Sep 30 2015, 04:00 PM
[quote name='mepstein' post='2245415' date='Sep 3... Sep 30 2015, 05:52 PM
jimkelly i'll try to blend ACQUISITION with ACTUAL BUIL... Sep 30 2015, 06:53 PM
mgp4591
i'll try to blend ACQUISITION with ACTUAL BUI... Oct 1 2015, 09:06 PM
jimkelly $35 ebay
actual unit as received Oct 1 2015, 06:33 PM
A&P Mech All those pieces and parts look familiar. :) What... Oct 1 2015, 06:50 PM
jimkelly Dutchman has been recommended by bigkat_83 who is ... Oct 2 2015, 08:52 AM
76-914
Dutchman has been recommended by bigkat_83 who is... Oct 2 2015, 09:47 AM
mgp4591 Sweet idea for the axles- I may just send my SVX a... Oct 2 2015, 10:38 PM
jimkelly sawtooths axles
>> has anyone used this dim... Oct 3 2015, 06:12 AM
76-914
sawtooths axles
>> has anyone used this di... Oct 3 2015, 08:20 AM
jimkelly your conversion was epic - others can see it here.... Oct 3 2015, 10:24 AM
jimkelly why I MUST HAVE a Subaru engine and trans :D
AL... Oct 3 2015, 06:15 AM
Chris H.
... Oct 3 2015, 01:34 PM
Justinp71
... Apr 1 2016, 05:37 PM
jimkelly OD of splined end of stock 914 axle is 1.066.
wha... Oct 7 2015, 12:56 PM
76-914
wh... Oct 12 2015, 08:20 PM
mgp4591
Jim - if you or someone will tell me how to remov... Oct 7 2015, 04:53 PM
jimkelly once upon a time, i had a legacy parts car and rem... Oct 7 2015, 04:03 PM
jimkelly Ms_UZ43u4CQ Oct 7 2015, 05:10 PM
mepstein Thanks guys.
I'll probably cheat and have on... Oct 7 2015, 06:08 PM
jimkelly decided to drive the pickup truck to mark's sh... Oct 9 2015, 11:34 AM
jimkelly finally got my 1975 back onto some wheels and tire... Oct 10 2015, 04:10 PM
jimkelly how could i best protect these pin holed longs wit... Oct 12 2015, 11:07 AM
Andyrew
how could i best protect these pin holed longs wi... Oct 15 2015, 04:15 PM
jimkelly my buddy - rat rod charlie - is on his way to dayt... Oct 12 2015, 03:38 PM
jimkelly got me some doors coming via series9's shop. Oct 15 2015, 02:51 PM
jimkelly my head light question thread at this link... pics... Oct 16 2015, 12:00 PM
jimkelly decided that I will just put a delrin spacer here ... Oct 18 2015, 05:54 AM
jimkelly new doors coming home today. guess i'll put w... Oct 30 2015, 02:56 PM
flmont Jim,..how do U intend to run the water lines under... Oct 30 2015, 10:12 PM
jimkelly under - it is tried and true - but thru longs give... Oct 30 2015, 10:36 PM
rightpedal Jim I laugh every time I see the "pickup... Oct 31 2015, 05:16 AM
jimkelly white doors are back on my 1975 and red doors are ... Oct 31 2015, 04:37 PM
914forme And to think I just man handle doors in place, put... Oct 31 2015, 05:09 PM
jimkelly thank god I had the hoist... no way could I have i... Oct 31 2015, 06:50 PM
jimkelly yesterday I picked up a fuse box section and a fro... Nov 1 2015, 08:03 AM
mepstein Save your old fuse panel in case you or someone el... Nov 1 2015, 09:07 AM
jimkelly mark - that is awesome - I am so glad I got a kid ... Nov 1 2015, 09:23 AM
mark - that is awesome - I am so glad I got a kid... Nov 1 2015, 09:33 AM
jimkelly just stripped down the bumper. i'll be return... Nov 1 2015, 10:26 AM
jimkelly well, I still don't understand how you guys ac... Nov 7 2015, 08:27 AM
Andyrew
well, I still don't understand how you guys a... Nov 7 2015, 11:18 AM
mepstein Pm me your address and I'll send down some cli... Nov 7 2015, 08:49 AM
jimkelly mark, how about I visit next week, I need to bring... Nov 7 2015, 08:58 AM
mark, how about I visit next week, I need to brin... Nov 7 2015, 09:09 AM
jimkelly guess if I just remove lens, maybe I would have a ... Nov 7 2015, 11:46 AM
914forme Small bit and bit holder does the trick also, remo... Nov 7 2015, 02:03 PM
jimkelly (( driver bit in fingers seems like a decent solut... Nov 7 2015, 02:19 PM
jimkelly since i have been getting my lights and guages rei... Nov 9 2015, 04:37 PM
jimkelly it turns out that my car has dash wiring for EGR a... Nov 11 2015, 10:22 AM
jimkelly tested my buddy's theory that my battery charg... Nov 14 2015, 09:45 AM
jimkelly did a loose bolt/wire check and found 3 nuts at bo... Nov 15 2015, 05:39 PM
jimkelly got me some stuff from 914rubber :) Nov 25 2015, 09:41 PM
jimkelly did a little something on my 75 today. got some s... Nov 29 2015, 12:27 PM
jimkelly think i found my parts car, a lowly ej22 in need o... Mar 31 2016, 02:18 PM
matthepcat ^^That motor has a factory forged crank ^^
You ca... Mar 31 2016, 02:47 PM
jimkelly one step closer... with a 1990 subaru legacy awd..... Mar 31 2016, 08:26 PM
76-914
one step closer...
BUT NOT TO TURBO :D
time to... Apr 1 2016, 08:41 AM
jimkelly i'm concerned. i knew the engine has some iss... Apr 1 2016, 01:10 PM
zipedadoo What year is the subaru? I used a 1996 ej22. I fou... Apr 1 2016, 01:54 PM
jimkelly 1990 subaru legacy awd.. must have been sitting fo... Apr 1 2016, 02:29 PM
Chris H. No the car in that clip is a 4 cylinder turbo car.... Apr 1 2016, 10:21 PM
jimkelly all he said was that he stopped running it cause h... Apr 2 2016, 05:57 AM
jimkelly ok, engine runs but weak. seems spark is ok but n... Apr 6 2016, 06:45 AM
jimkelly got me second ej22 today $100. Apr 6 2016, 06:02 PM
Andyrew
You and you... Apr 12 2016, 03:34 PM
jimkelly my 1990 subaru legacy 5spd awd, pulling harness, t... Apr 12 2016, 03:06 PM
jimkelly thank you andy :D
at a gas station on the way b... Apr 12 2016, 04:11 PM
jimkelly great thread on repairing shielded suby wires.
htt... May 29 2016, 10:27 AM
jimkelly pulled engine and trans last night. made a cradle ... Jun 10 2016, 06:07 PM
76-914 The Fun begins Jim. :popcorn: You may need a few ... Jun 10 2016, 06:24 PM
jimkelly I have several wires to fix on my harness. someho... Jun 11 2016, 03:19 PM
I have several wires to fix on my harness. someh... Jun 11 2016, 03:43 PM
arkitect
Cool use of... Jun 10 2016, 10:37 PM
jimkelly thanks :)
got me second ej22 today $100.... Jun 11 2016, 03:16 PM
jimkelly ambitious, no. :poke: poking myself :D
frugal... Jun 11 2016, 04:35 PM
76-914
fruga... Jun 12 2016, 03:24 PM
frug... Jun 12 2016, 05:46 PM
rightpedal I might be able to help with the cradle. Want to ... Jun 12 2016, 07:00 PM
jimkelly I already have the suby cradle and trans hangers f... Jun 12 2016, 07:21 PM
jimkelly i bit off topic but i am making my recently bought... Jun 27 2016, 05:58 AM
jimkelly engine stand getting closer to finished and closer... Jul 1 2016, 09:10 PM
jimkelly latest of engine on stand... amnd video of harness... Jul 13 2016, 04:51 PM
jimkelly decided to try a microsquirt based on many youtube... Apr 5 2017, 06:15 AM
76-914 Good to see you haven't given up. MS is easier... Apr 5 2017, 07:59 AM
jimkelly guess i'll cross that bridge if i ever get the... Apr 5 2017, 10:46 AM
jpnovak MS2 ECU board fits nicely inside a stock Suby ECU ... Apr 5 2017, 02:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th September 2026 - 12:01 PM |
