| dangerranger01 |
Oct 2 2015, 09:09 PM
Member ![]() ![]() Group: Members Posts: 145 Joined: 12-August 05 From: Boring, Oregon U.S.A. Member No.: 4,578 Region Association: None |
Just my luck, i snapped off a bolt that held the rear trunk latch on. Pulling it to replace the spring that broke. Anyone else experience this?? I'd venture to say that tig welding a head on to get a wrench on wouldn't work....probably snap that off too.
Oh, and I snapped an easy-out in it too. Just great!! What do you think of welding a short stud on...looks like there is enough room for no interfence with the bottom latch assembly....I need a beer. (IMG:http://www.914world.com/bbs2/uploads_offsite/i718.photobucket.com-4578-1443841759.1.jpg) Oh, and the other bolt that did come out thread's looked nasty.... (IMG:http://www.914world.com/bbs2/uploads_offsite/i718.photobucket.com-4578-1443841759.2.jpg) |
| Spoke |
Oct 11 2015, 09:34 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
What about welding on a bolt, cut the head off and use as a stud?
No real reason to keep it like the manufacturer designed it. It won't be seen most of the time. As long as it holds the latch plate on... |
| EdwardBlume |
Oct 11 2015, 10:37 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
What about welding on a bolt, cut the head off and use as a stud? No real reason to keep it like the manufacturer designed it. It won't be seen most of the time. As long as it holds the latch plate on... Well, the car IS a historical time piece of great significance.. and its mystery is only exceeded by its power. |
dangerranger01 Broke bolt for trunk latch... Oct 2 2015, 09:09 PM
dangerranger01 Might try this....but i think that bolt is rusted ... Oct 2 2015, 09:13 PM
jsh What about drilling it out and then tapping Oct 2 2015, 10:31 PM
steuspeed Rusted stud at the 7:00min mark.
You could also ... Oct 2 2015, 10:43 PM
jeffdon You guys have trunk latches? Oct 2 2015, 10:48 PM
RobW Start with a small drill bit, then use PB blaster.... Oct 3 2015, 04:12 AM
MMW Looks to be below flush with surface? This is why... Oct 3 2015, 07:27 AM
dangerranger01 It looks like there is that spray foam crap behind... Oct 10 2015, 05:35 PM
cary When you get there. I think I have a hood we can u... Oct 11 2015, 07:50 AM
Hank914
What about welding on a bolt, cut the head off an... Oct 11 2015, 10:30 AM
dangerranger01 Well I fixed it. Tried to build a bead up with my ... Nov 17 2015, 07:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:18 AM |
