Mugs914 |
"Hey, yellow IS faster!" ![]() ![]() ![]() Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region ![]() |
You guys may or may not remember the Junk Yard Dawg, the race car tub we got from a buddy and put on the track with bits scrounged up from around the shop (Pics were posted a while back in the track car pics thread).
![]() Well, the intention has always been to get rid of the sewer pipe cage and build something much more appropriate. The cage that was in the car was made of 1.75" x .125" tubing and had so many tubes in so many places there was almost no place to put your feet! Besides that it was horribly heavy (140 pounds, as it turns out (IMG:style_emoticons/default/blink.gif) ). We've been toiling away at the new version and this is what we came up with. It's built from 1.5 x .095 mild steel and is a low front hoop style. Not quite finished yet, there are a few things to add like a front hoop that goes over the steering column and attaches at the long and the center tunnel (Like a formula car). The main hoop will be faired in to the targa bar so it will look like just a wider targa bar. To get the seat mounted closer to the center of the car we clearanced the center tunnel by about two inches and then reinforced it with .090" sheet metal along the top. The design is a bit unconventional, but does conform to the regs for anyone we are likely to run with and the inspectors that have seen it so far are happy with it. The guy sitting under the broomstick is a little over six feet and, as you see, fits under the stick rather easily. I'm 5'8", so I may need a phone book in the seat. We'll see where we end up weight wise, but right now the estimate is somewhere between 40 to 60 pounds lighter than the sewer pipes. Pics below... |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
Mugs - A couple thoughts...on my car, I found the steering wheel to be slightly offset to the outside of the car. Not that much really but definetly not squared up to the car front to rear. Moving the seat towards the center would make this more pronounced. Is your car not that way?
Also, I am a bit too conservative when it comes to open top cars but that exposure to your chest and head make me bit nervous. Here is what I did with my car to make it somewhat Funny-Car like to give me at least a fighting chance...should things come flying in at me. I can appreciate the hard work - keep it up! Tony New Cage ![]() Old Cage ![]() |
Mugs914 |
Mugs - A couple thoughts...on my car, I found the steering wheel to be slightly offset to the outside of the car. Not that much really but definetly not squared up to the car front to rear. Moving the seat towards the center would make this more pronounced. Is your car not that way? Actually, the steering wheel was offset to the right a bit and moving the seat over got everything lined up a bit better. The steering column sits at a little bit of an angle relative to the car center line (Comes that way from the factory and even shows up on the blueprints!), but the center of the wheel itself was to the right of the seat center line before the mods. Also, I am a bit too conservative when it comes to open top cars but that exposure to your chest and head make me bit nervous. Here is what I did with my car to make it somewhat Funny-Car like to give me at least a fighting chance...should things come flying in at me. I can appreciate the hard work - keep it up! Tony I'm a lot like you actually when it comes to open cars! What isn't in the pics (Because it isn't in the car yet (IMG:style_emoticons/default/tongue.gif) ) is a front hoop that is probably very similar to what you have in your sports racer. It basically goes from the center tunnel, over the steering column, and down to the left side long. The top will be a bit higher than the top of the wheel and will be braced to the forward hoop. The car will also have a tonneau that completely covers the cockpit area with a small opening for the driver's head. Kind of like this but without the big hole to the driver's left: ![]() We're also considering a hoop over the driver's head that would go from the center tunnel to the long and tie into the main hoop and again, would look a lot like what you've got in you sports racer. I'll post up some pics as we make more progress. Thanks for the concern, BTW! Mike |
Lo-Fi Version | Time is now: 13th June 2024 - 03:58 PM |
