| jimkelly |
Oct 16 2015, 01:02 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my car is without a relay box and my fuse panel may be a little jacked up, so I will be replacing it. I am checking my lights using a battery charger which seems to be putting out about 9.2 volts.
I've pulled my headlight motors cause i will be running my car with lights UP all the time. when I pull my headlight switch out, I get tail lights, front amber and front side amber, but no head lights. I was wondering if the power to the headlight motors in part of the ciurcuit to make the head lights function? when I pull my emergency light switch, I hear a buzz in its flasher, maybe its flasher is no good. i turned ignition key and did see my wipers work, but real slow, i'm guessing 9 volts is not quite cutting it. yeah, i am missing a few fuses, got a big pack on oprder from an ebay seller. Attached image(s)
| JDW914 |
Oct 16 2015, 01:19 PM
Newbie ![]() Group: Members Posts: 25 Joined: 27-April 11 From: Toledo, Ohio Member No.: 12,990 Region Association: Upper MidWest |
Dumb question, but: Are you pulling the switch out all the way? It has two positions, with the first being parking-lights-only and the second being all lights, which should raise the headlights.
Other than that, the motors themselves act as headlight switches. At the ends of their travel, the same switches that stop the motor rotation connect power to the lights. If the motors are removed, this whole circuit needs to be bypassed, but is contained in the motor casing itself, so just plugging the power wire into the headlamp should make it work properly. |
jimkelly headlights power question Oct 16 2015, 01:02 PM
jimkelly I think you are answering my question, seems I nee... Oct 16 2015, 01:22 PM
jimkelly swapped around some fuses and turned the ignition ... Oct 16 2015, 01:48 PM
Dave_Darling The headlight motor wires are only for the headlig... Oct 16 2015, 05:27 PM
jimkelly dave - thank you - I will - jim Oct 16 2015, 05:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 10:01 AM |
