REMOVE Heater controls and fresh air box? |
itchybro |
Oct 19 2015, 01:45 PM
Newbie Group: Members Posts: 14 Joined: 3-June 15 From: Knoxville Member No.: 18,794 Region Association: South East States |
I'm in the process of trying to extract bit's from a "parts car" that mine doesn't have.
I got the gas tank out last night and hope to tackle the ventilation system this evening. (Tho I'm also trying to extract the wiring harness. Should I do that first?) Also would help if i could get the dash off too. (This is my first "try to save and not destroy what you need" project. ANY advice is appreciated. This helped a lot. I just need to do it in reverse http://www.914world.com/bbs2/index.php?s=&...t&p=1066336 Thanks Phil |
barefoot |
Oct 19 2015, 05:56 PM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
have to install mine as well, but have heard that removing the 2 vertical straps helps get the center air box in there, probably need to gently pry up in the cowl.
i have also shaved a lithe plastic off one end of the 2 diverter valves where they enter the firewall so they will slip into place. Otherwise I could not get them in for a test fit. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:23 AM |
