| brooks944 |
Oct 21 2015, 05:09 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
My 1.8 L-jet was running poorly and thanks to a member I found out the AFM connector was disconnected, yes I'm clueless about the 914. It ran better after connecting, but would not start when cold with the connector plugged in. It would start with it connected when warm. It started for a couple of days with it unplugged. After starting I would plug it back in and it ran better than it has since I got it about a year ago. I left it plugged in and tried to start without any luck. Have tried for the last couple of days, both with and without it connected. Still no start. What should I do next?
Thanks, Rick |
| brooks944 |
Oct 22 2015, 04:32 PM
Thanks Jeff, you have the best FI reference material. I did have a guy come by today who is a body guy and mechanic, very nice to come to my house. He suggested we hook up a wire from the positive on the battery to the hot on the coil. Car started right up. When the wire was off, the car died. Really don't want to change the ignition switch again, what a pain! Suggestions on where to check next?
Thanks, Rick |
brooks944 75 1.8 won't start Oct 21 2015, 05:09 PM
Jeff Bowlsby Start by becoming familiar with L-Jet by reviewing... Oct 21 2015, 05:42 PM
Jeff Bowlsby Double relay or connections to it. Oct 22 2015, 05:13 PM
brooks944 Thanks Jeff, I will check those. I do have anothe... Oct 22 2015, 05:15 PM
Jeff Bowlsby Its a place to start anyway, no promises that... Oct 22 2015, 05:31 PM
Dave_Darling I don't believe the double relay powers the co... Oct 22 2015, 06:46 PM
timothy_nd28 :agree: Oct 22 2015, 06:52 PM
timothy_nd28 At the relay board, you have 2 main connectors. O... Oct 22 2015, 10:32 PM
brooks944 I am not versed with electrical testing. To test ... Oct 23 2015, 10:48 AM
Kansas 914
I am not versed with electrical testing. To test... Oct 23 2015, 12:36 PM
brooks944 Thanks Kansas. Where is the best place to get a s... Oct 23 2015, 12:41 PM
Kansas 914
Thanks Kansas. Where is the best place to get a ... Oct 23 2015, 12:50 PM
timothy_nd28 Don't worry about testing, it's a good cha... Oct 23 2015, 01:01 PM
brooks944 Thanks, where is the best place to get the switch.... Oct 23 2015, 01:16 PM
Kansas 914
Thanks, where is the best place to get the switch... Oct 23 2015, 02:29 PM
brooks944 Thanks everyone. I got the new oem switch in toda... Oct 28 2015, 03:30 PM
brooks944 Oh, it doesn't even turn over now, all other e... Oct 28 2015, 03:32 PM
timothy_nd28 Can you post a pic of your relay board? Oct 28 2015, 06:50 PM
brooks944 Relay board picture:
Oct 29 2015, 05:02 AM
timothy_nd28 Remove the lonely yellow wire (has red circle arou... Oct 29 2015, 09:20 AM
brooks944 Tried it in both of the rear one, not turning over... Oct 29 2015, 01:57 PM
timothy_nd28 Okay, leave that yellow wire plugged into one of t... Oct 29 2015, 02:08 PM
brooks944 Do I put the positive from the voltmeter on the pi... Oct 29 2015, 02:32 PM
timothy_nd28 Yep, I would pull off the 14 pin connector, and in... Oct 29 2015, 02:36 PM
brooks944 Thanks it may take a day or two to test, I will le... Oct 29 2015, 04:39 PM
brooks944 The wires to the coil also look pretty fragile, pl... Oct 29 2015, 05:19 PM
brooks944 One of the 914World local experts came by yesterda... Nov 2 2015, 03:50 PM
rhodyguy There is a small wire near the interlock relay scr... Nov 2 2015, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:02 AM |
