There Goes The Neighborhood, Sorting out an adopted V8 build |
whitetwinturbo |
Jul 7 2015, 05:21 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
I'm just "wading" into this project since it rolled off the shipping truck (IMG:style_emoticons/default/yikes.gif) 99% rust free California car now in SoCal after sitting in a garage for years without being (IMG:style_emoticons/default/driving-girl.gif). My neighbors are now giving me the "hairy eyeball" since I fired it up to pull it up into the garage....and it was a bit loud (IMG:style_emoticons/default/happy11.gif) . Now taking inventory of what it is (IMG:style_emoticons/default/dry.gif) and making a list of what-to-do and in what order it might be done. I'm starting with draining and renewing all water, oil, brake and transmission fluids. I expect the juices to be a little funky since just sitting unused continues the 'chemistry'. The wiring looks a little scary too. Many of them in the engine compartment (box behind driver) were cut and lead nowhere. Hum. It would be good to hear from other V8 'Loons' (IMG:style_emoticons/default/poke.gif) who may be able to help me avoid to much (IMG:style_emoticons/default/headbang.gif). Let the 914 madness continue! |
whitetwinturbo |
Oct 27 2015, 06:37 PM
I have been working on the brakes since the fluid was probably not changed for 5 years. My brakes are all non-914 so the 14mm booster will be replaced with a sourced 19mm.
A problem surfaced when I decided to upgrade to these: Here's the problem: Notice the material "taken" by the threads? It was VERY difficult to remove this bleed nipple. I used a breaker bar on the wrench but only turned it slightly and then waited after a PB spray to keep cool....I did not want to break it off. I think the PO or service folks accidently overtightened it. I am hoping to retap/clean the caliper to install new item above but I have this repair kit if that does not seal correctly: |
Lo-Fi Version | Time is now: 6th June 2024 - 01:22 PM |
