> 75 1.8 won't start, Looking for help!
brooks944
post Oct 21 2015, 05:09 PM
My 1.8 L-jet was running poorly and thanks to a member I found out the AFM connector was disconnected, yes I'm clueless about the 914. It ran better after connecting, but would not start when cold with the connector plugged in. It would start with it connected when warm. It started for a couple of days with it unplugged. After starting I would plug it back in and it ran better than it has since I got it about a year ago. I left it plugged in and tried to start without any luck. Have tried for the last couple of days, both with and without it connected. Still no start. What should I do next?
Thanks,
Rick
brooks944
post Oct 28 2015, 03:32 PM
Oh, it doesn't even turn over now, all other electrical stuff seems to be working.
brooks944   75 1.8 won't start   Oct 21 2015, 05:09 PM
Jeff Bowlsby   Start by becoming familiar with L-Jet by reviewing...   Oct 21 2015, 05:42 PM
brooks944   Thanks Jeff, you have the best FI reference materi...   Oct 22 2015, 04:32 PM
Jeff Bowlsby   Double relay or connections to it.   Oct 22 2015, 05:13 PM
brooks944   Thanks Jeff, I will check those. I do have anothe...   Oct 22 2015, 05:15 PM
Jeff Bowlsby   Its a place to start anyway, no promises that...   Oct 22 2015, 05:31 PM
Dave_Darling   I don't believe the double relay powers the co...   Oct 22 2015, 06:46 PM
timothy_nd28   :agree:   Oct 22 2015, 06:52 PM
timothy_nd28   At the relay board, you have 2 main connectors. O...   Oct 22 2015, 10:32 PM
brooks944   I am not versed with electrical testing. To test ...   Oct 23 2015, 10:48 AM
Kansas 914   I am not versed with electrical testing. To test...   Oct 23 2015, 12:36 PM
brooks944   Thanks Kansas. Where is the best place to get a s...   Oct 23 2015, 12:41 PM
Kansas 914   Thanks Kansas. Where is the best place to get a ...   Oct 23 2015, 12:50 PM
timothy_nd28   Don't worry about testing, it's a good cha...   Oct 23 2015, 01:01 PM
brooks944   Thanks, where is the best place to get the switch....   Oct 23 2015, 01:16 PM
Kansas 914   Thanks, where is the best place to get the switch...   Oct 23 2015, 02:29 PM
brooks944   Thanks everyone. I got the new oem switch in toda...   Oct 28 2015, 03:30 PM
brooks944   Oh, it doesn't even turn over now, all other e...   Oct 28 2015, 03:32 PM
timothy_nd28   Can you post a pic of your relay board?   Oct 28 2015, 06:50 PM
brooks944   Relay board picture:   Oct 29 2015, 05:02 AM
timothy_nd28   Remove the lonely yellow wire (has red circle arou...   Oct 29 2015, 09:20 AM
brooks944   Tried it in both of the rear one, not turning over...   Oct 29 2015, 01:57 PM
timothy_nd28   Okay, leave that yellow wire plugged into one of t...   Oct 29 2015, 02:08 PM
brooks944   Do I put the positive from the voltmeter on the pi...   Oct 29 2015, 02:32 PM
timothy_nd28   Yep, I would pull off the 14 pin connector, and in...   Oct 29 2015, 02:36 PM
brooks944   Thanks it may take a day or two to test, I will le...   Oct 29 2015, 04:39 PM
brooks944   The wires to the coil also look pretty fragile, pl...   Oct 29 2015, 05:19 PM
brooks944   One of the 914World local experts came by yesterda...   Nov 2 2015, 03:50 PM
rhodyguy   There is a small wire near the interlock relay scr...   Nov 2 2015, 05:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:01 AM
