> Facet Fuel Pumps, 34 year old pump finally died
DonTraver
post Sep 22 2004, 08:43 AM
The original fuel pump on my 914-6 finally died, started to die on the way to GAF, didn't make it, but made it home. I priced new fuel pumps, $370-$450, ouch.
I replaced the pump with a FACET pump, plugged return line. New pump runs 4-7 psi, 32 gallons per hour. Fuel pressure runs at around 5 1/4 psi at idle. Old pump put out 5 psi at idle.
I seem to be getting vapor lock after turning engine off and fuel lines absorb radiant heat from engine. The new pump fit on the orginal fuel pump rubber mounts in engine bay corner, and it was a nice, neat installation.
I picked up some 2000 degree tubing heat sheild yesterday and will install over fuel lines for radiant heat.
The question is, "should I reconnect the return fuel line with a orfice fitting and what size orfice should the fitting have, or is it just a hit or miss deal?".
Any suggestions will be appreciated, Thanks
seanery
post Sep 22 2004, 09:03 AM
waiting to rebuild whitey!
I have a facet on both of my teeners, although I have never driven the -6. The -4 has it in the stock location with no trouble, vapor lock, etc...
DonTraver   Facet Fuel Pumps   Sep 22 2004, 08:43 AM
Aaron Cox   no fuel pressure regulator?   Sep 22 2004, 08:45 AM
DonTraver   I matched the new pump as close as I could get to ...   Sep 22 2004, 08:57 AM
seanery   I have a facet on both of my teeners, although I h...   Sep 22 2004, 09:03 AM
john rogers   Which Facet pump did you get? If it is the small c...   Sep 22 2004, 09:28 AM
DonTraver   Just finished putting the heat shielding on the fu...   Sep 22 2004, 11:19 AM
john rogers   Don, I checked a racing website that gives a rough...   Sep 22 2004, 12:09 PM
maf914
- Lo-Fi Version Time is now: 11th July 2025 - 08:57 AM
