Mini V8 Thread, Installing my old v8 in a members 914 |
Andyrew |
Oct 20 2015, 08:19 AM
There will be a lack of progress on my car until I get this members 914 running with my v8 setup. The only requirement is that the engine will start, run, and move the car.
Below is my list of work to do. Pull Fuel Tank Replace stock fuel lines Plumb fuel pump Replace firewall shift bushing Cut holes for radiator lines in front trunk Mount radiator lines Cut notch for HEI Dizzy Clearance valve cover Bolt up engine/trans Bolt up cv joints Install shoft linkage and adjust Install distributor and carb Install clutch, throttle and speedo cables Wire starter, dizzy, alternator Test fire Flush coolant Bleed brakes Drive Total hours involved is anticipated at 26 by myself. I origially agreed that the owner would have the car 100% ready for the swap and I would only have to do the v8 portion, (which I have a anticipated at 20.5hrs) however the fuel line issue, firewall shift bushing, and bleeding the brakes are all going to be done on a T&M basis. Overall its a good looking body with a few dents and paint that shows its age. There is a bit of rust in the firewall and battery tray and some in the pass front door jamb, but the rear suspension console looks great. I think its a great candidate for a conversion. |
Andyrew |
Oct 31 2015, 07:35 PM
Lo-Fi Version | Time is now: 12th June 2024 - 12:41 AM |
