> Cleaning Paint Overspray off of dash, SUGGESTIONS?
stevegm
post Oct 31 2015, 01:50 PM
I am embarrassed to admit that during the months I was prepping my car for paint, apparently a light mist of overspray made it onto the dash. Although it isn't a perfect dash, I really don't feel like changing it out.
When I clean it with leather cleaner it comes out looking pretty nice. But, then when it dries, the white comes back.
Suggestions as to how I can clean it?
scotty b
post Nov 2 2015, 12:27 PM
rust free you say ?
Lacquer thinner will be the best, but as others said try a small spot first. I think the problem you're going to have is the chemicals are going to destroy the outer coating the vinyl has that makes the sheen, and acts as the UV protectant.
Many years ago, I cleaned a set of FILTHY tan seats ( 914 ) with Purple Stuff and a soft plastic bristle brush and ended up removing that coating. The seats ended up very dull, and over a couple years time started to crack apart (IMG:style_emoticons/default/sad.gif)
stevegm   Cleaning Paint Overspray off of dash   Oct 31 2015, 01:50 PM
r_towle   Lacquer thinner first. Acetone if required, but cl...   Oct 31 2015, 02:11 PM
stevegm   Lacquer thinner first. Acetone if required, but c...   Oct 31 2015, 02:14 PM
SirAndy   So, lacquer thinner should be ok? Try on a small p...   Oct 31 2015, 02:17 PM
r_towle   Test I. A corner, but it should be fine. Acetone i...   Oct 31 2015, 02:16 PM
r_towle   Actually goof off works great. It's soap mixed...   Oct 31 2015, 02:20 PM
sb914   What about simple green ,way less toxic   Oct 31 2015, 02:23 PM
bandjoey   And orange hand cleaner and stiff brush. It'l...   Oct 31 2015, 02:50 PM
Chris914n6   Any of the mentioned paint removers are going to d...   Oct 31 2015, 03:44 PM
914forme   clay bar?, it was originally designed to remove ov...   Oct 31 2015, 04:44 PM
injunmort   acetone or laquer thinner   Oct 31 2015, 06:50 PM
bfrymire   How about just re-dying the dash? Remove as much ...   Oct 31 2015, 07:13 PM
porschetub   How about just re-dying the dash? Remove as much...   Nov 1 2015, 12:33 PM
rhodyguy   Try some white vinegar mixed with HOT water in a t...   Nov 2 2015, 09:47 AM
JamesM   Before messing around with chemicals or anything e...   Nov 2 2015, 10:56 AM
Mr Pharmacist   I used fine wire wool and water to remove the over...   Nov 2 2015, 11:01 AM
MJHanna   Try rubbing alcohol first before the paint thinner...   Nov 2 2015, 11:03 AM
scotty b   Lacquer thinner will be the best, but as others sa...   Nov 2 2015, 12:27 PM
stevegm   Thanks everyone for their suggestions. I am trying...   Nov 6 2015, 04:41 PM
CooltimesJr   try the Magic Eraser or a generic brand first, we ...   Nov 6 2015, 07:04 PM
Cracker   I second the "Alcohol" suggestion...this...   Nov 6 2015, 07:11 PM
stevegm   I second the "Alcohol" suggestion...thi...   Nov 6 2015, 07:18 PM
Cracker   Yes. It was over spray...not on the dash (I took m...   Nov 6 2015, 07:27 PM
stevegm   Yes. It was over spray...not on the dash (I took ...   Nov 6 2015, 07:34 PM
Cracker   Either way, I'd use a small tooth brush to wor...   Nov 6 2015, 07:37 PM
CooltimesJr   Either way, I'd use a small tooth brush to wo...   Nov 6 2015, 08:07 PM
RickS   I would skip trying to clean it and just lightly s...   Nov 7 2015, 10:12 AM
- Lo-Fi Version Time is now: 9th July 2025 - 04:09 PM
